my wife is a chemical and bio grad and works with this stuff on a daily basis, if you need questions asked just pm and i'll have her give you her best answer
Runners:
84 200s
05 rancher
12 rancher
Gonna try the Red Kote in a few days. Read all of this have a couple of questions.
Does the petcock filter tube just pull out?
When I drain the RK, do I use a wire brush/Q-tips to clear out the petcock filter hole so that the filter can be re-installed? Do I re-install the filter as soon as I leave the tank to dry?
3 steps to the prep, right? Muriatic acid, baking soda flush, and then acetone. And the flash rust will be fine when using the RK.
Thanks
My Rags
I pushed the filter tube into the tank with a punch and got it out the fill hole....
Is it re-usable when you do that?
My Rags
