Results 1 to 15 of 20
Thread: is about 11:1 to high on pump gas.
    Jun 2004
    geraldton, west australia
    1,068
    hi just found out this piston im getting makes the compression ratio about 11:1, would i have to run pure race gas with that.
    LIVELOVERIDEDIE
    1981 Honda Atc 124R-Racer project
    2005 Giant STP 1- rollin' on 26's
    Nov 2004
    Waterloo IL
    2,701
    What kind of bike? Air cooled I think is border line, liquid cool you will be fine. I'm wanting to see what others have to say about this too.
    If it's in the ATC110. I think you should be ok with 93 octane since it's a smaller piston. If you get a cam with more overlap it will lower your dynamic compression as well.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Anaheim
    1,270
    run the atc110 with sythetic motor oil, and 93 octane * wil lbe fine, i know of a guy who runs a 350x with a 12:1 piston on 92
    adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    May 2002
    Southeastern Wisconsin
    3,658
    On an air cooled you'll be lucky to run 93 with 11:1. Any higher you'll need race gas for sure if everything is working right.
    Nov 2004
    Waterloo IL
    2,701
    I could be wrong but a 350X with 12 to 1 on 92 octane seems really questionable to me.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
    Aug 2004
    East Central, Missouri
    546
    Post LOTS of variables to watch with premium and 12:1....
    What I live by with regards to high compression:
    1. You have to be religious about keeping FRESH premium (keep Sta-Bil in there if you insist on "storing" fuel in your trike's tank, come hell or high water) in the tank. Yes, fuel does go bad! And faster than you think.
    2. Jetting is critical (lean is no longer mean it becomes a recipe for disaster).
    3. Timing is also critical (make SURE it's spot-on).
    4. Make sure the decompression cable adjustment (350X, for example) is spot-on or you'll beat your leg to death.
    5. You're not going to hear detonation (pinging) over that "bad boy" pipe and/or your friend's ride until it's WAY too late and you've done BIG $$ damage.
    Higher compression on pump gas?
    Check out the old Cannondale (now ATK) quads:
    They are 12.5:1 on premium pump gas BUT...they have computer controlled timing and fuel injection...thus no quirky fueling/ignition problems.
    They're always perfect.
    Don't worry, it CAN be done but don't cheap out on parts or tuning or you'll regret it.
    May 2002
    3,658
    Quote Originally Posted by MO350X
    The Cannondale quads should be no where near this thread. Those are liquid cooled motors that keep the temps down a lot more then an air cooled. Of course you will be able to run higher compression ratios without as many problems. Now 12:1 in an air cooled on pump gas just isn't gonna happen unless something is wrong.
    Washingtons Crossing, Pa.
    2,977
    My Scrambler 400 has a 12:1 cool head and it runs on 92 octane just fine. Also, compression should not effect jetting - you are just compressing the same amount of fuel charge into a smaller area. If your jetting was correct before the piston or head modification, it will in theory be correct after it. However, you should always plug check after any motor, carb or intake modification. (TimSr will tell you to check it even if you've changed fenders, tires or even applied a new decal ..... lol)
    May 2002
    3,658
    Quote Originally Posted by Wickedfinger
    Isn't the scambler liquid cooled?
    2,977
    Yes, yes ....... I don't think it would matter air or liquid cooled. If anything, the tolerences on an A/C motor are, of course, much less allowing for more flexability ... yada yada .... anyway, its the incoming fuel charge thats responsible for over 80% of the cooling on any A/C motor - I think 91 - 93 pump gas should burn slower and cooler enough to work fine. Worse case - you have to buy octane booster if it pings.
    2,977
    Quote Originally Posted by TrikerR
    11:1 dosent sound right. A 10.5:1 Wiseco medium compression runs fine on pump gas.
    Jun 2004
    Brazil, Indiana
    1,389
    i just put 92 in my 200x with a 12:1 wiseco bored to the max and it runs really good...it ran fine on 87 too...but i can definetly tell a difference between them
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    May 2002
    3,658
    Ouch, my heart aches from words like this. 11:1 in a liquid cooled could get by with almost 87, an air cooled would need 93 to handle it.
    Jun 2004
    1,068
    thats the piston there.
    (email from seller)
    This piston is 6.3mm Dome with Valve Reliefs. Compression Ratio is unknown but I estimate it to be around 11 to 1. If you have any further questions please let me know
    im just going by what they say. if i cant get 93 octane here, will i have to run octane boosters.
    thanks guys for your help
    LIVELOVERIDEDIE
    2,977
    That looks like a 12:1 to me.
