Results 1 to 15 of 17
Thread: Tri-Moto trans oil question
    Aug 2004
    PA
    190
    As some of you know, I waterlogged my tri-moto. I drained all the gas and float bowls and all that good stuff. I wanted to drain the engine oil, and trans oil and refill with fresh oil. So I drained the engine oil, but then couldn't figure out where to drain and fill the trans oil. Is the engine and trans oil the same? Thats how it is on my motorcycle, and that's how it appears to be on this trike.
    Mar 2005
    Alberta
    503
    They are one & the same.
    wheelie king's Avatar
    wheelie king is offline Aficionado of white surprise sauces. Arm chair racerRoostin Away
    Central FL USA
    1,174
    YES- both the same-
    After waterlogging her, I'd run it for about an hour or 2 with the new oil, then change it AGAIN. Cheap insurance if you ask me, and then you're double sure that your crankcase is clean.
    1986 Honda ATC 200 S
    Some quads and a S x S
    Supporter of Uncle Rico's football camp. Since 1982.
    If you are reading this in English, thank a U.S. Military VET. ΜΟΛΩΝ ΛΑΒΕ
    Aug 2004
    Ab Canada
    4,368
    you are BOTH wrong- trimoto 125 is a 2 STOKE there is no "engin oil" so to speak of except for the stuff you mix with your gas-thats what lubricates the piston-crank the gear box is a seperate compartment that runs 10w40 for motor oil in ther to lube the transmission-the filler for the transmission should be on the left or right side case
    1985 Tri-Z-
    Central FL USA
    1,174
    OK- then I stand corrected. A 2 stroke is exactly that. So if yours is a 2 stroke, disregard my post. Homemade did not say WHAT model tri moto he had, and I thought he was speaking of a 4 stroke tri moto. Sorry for the confusion.
    Rittman, Ohio
    6,276
    He never mentioned which model Trimoto is was. I too assumed he meant a 4 stroke model, if he drained "the engine oil", and you dont very often get water in the plastic injector oil tank. Whether is two stroke or 4 stroke, there should only be one place to drain oil out of the motor.
    Aug 2004
    PA
    190
    Sorry, it is a 2 stroke. What I drained out is on the right side of the trike, where the 2 stroke engine oil goes. It's not a pre-mix set-up. So, if the trans fluid is different than the "engine oil", where is the drain and fill for it? Where you put the oil in is not a plastic tank though, there is a plastic cap that you unscrew, and the fluid goes right in the case.
    Rittman, Ohio
    6,276
    If I understand right, you drained the tank that is separate from the motor that you put 2 cycle oil in. Id be amazed if you actually got water in there, but if that is the one you drained, you also have oil in the motor for tranny and clutch lubrication. The drain plug should be a large head bolt in the bottom underbelly of the motor, usually near the center .
    Aug 2004
    PA
    190
    Ya, there was water in there. Unscrewed the cap, and it was to the top, coffee with lots of cream in color. I took out the bottom bolt you are referring to after I drained the 2 stroke oil, and nothing came out. Then I put 2 stroke oil in, then the 2 stroke oil came out that bottome plug under the trike. Thats why I am wondering if it is the same oil.
    Jul 2004
    Mud hill. close to water !
    3,658
    Whoa...
    Somehin ain't right.
    should be oil .. 10w30 or 40 ( depends on your local temps ) for the transmission gears.. and clutch..
    and then 2 stroke oil for the engine ( yours seems to be auto-injection .. so you don't have to manually mix it ! )
    When you fill with gas.. you also usually fill the 2 stroke oil res..
    but there should be a seperate drain / fill for the gears.
    Currently :
    Aug 2004
    PA
    190
    Son-of-a-bEE-OTCH!! Now I am glad I sunk this thing. I did some detective work and looked at the microfiche for my trike. The "oil tank" it shows on the microfiche, doesn't exist on mine. I think the last owner was an idiot, and so am I. He told me where you fill the trans oil is where to put the engine 2 stroke oil. That's what I get for listening to people. Apparently SOMEONE eliminated the oil injection, and went to premix. Ok, lets think about this for a minute.....................I RAN MANY TANKS OF GAS THROUGH IT WITH NO OIL!!!!!!!!! I can't believe this thing stayed together. Oh, and by the way, read my post here about my problem with OVERHEATING. Thanks everyone for the help, you all saved my but here before I did any REAL damage. Someone slap the back of my head.
    http://www.3wheelerworldforums.com/s...ad.php?t=31846
    Aug 2004
    PA
    190
    Oh, by the way, what gas/oil mix should I run?
    Jul 2004
    3,658
    Soooo.. you've been running 2 stroke oil in your tranny.. and no oil in the engine !!
    wow..
    as for the mix.. depends on the 2 stroke oil you are using.. the bottle usually mentions what to use.. 32:1 is usual.
    Currently :
    Aug 2004
    PA
    190
    Quote Originally Posted by bigredhead
    wow..
    Wow dot dot.......ok, not too bad, I am expecting worse though! I am ready for the abuse.
    Mar 2004
    37
    Don't feel too bad. I had a cousin(female) that put transmission fluid in the brake resivour, and brake fluid into the transmission on her car. She later wondered why it leaked from everywhere and the tranny blew up.
