Ok The atc only has about 3 hours on the rebuilt motor. The problem is its fouling the plug over and over again. The carb has been rebuilt and has the stock 95 main jet in it. I tried ajusting the needle jet to the lean out the carb but that didn't help. Then I tried ajusting the float to make it leaner and that didn't work. The plug is still carbon black and fouled. Timing is on and the valves are set right, Pulse generator and coil are fine, air gap on pulse is set right. idle and pilot air set right. Any body got any ideas
Thanks
Rob
