Results 1 to 11 of 11
Thread: Split Rims
    Duluth MN
    803
    Split Rims
    Whats the point, any advantages or dis???
    Confused As A Hungry Baby In A Topless Bar!!!
    '04 Honda CRF250R
    '82 Honda 200 4'sale soon
    '90 and '91 Arctic Cat Prowler 440
    '81 Kawasaki LTD 440 Belt Drive!!
    '92 Yamaha Warrior 350
    '05 DS 90
    Helmet save'd my friend's life, and mine, wear one!!!
    Trying is the first step to failure
    3ww Needs an iPhone app
    Jul 2004
    Mud hill. close to water !
    3,658
    You don't have to pry the bead over the rim !!
    Currently :
    Poplar, WI
    531
    the are some front tires like the 23.5x8x11, that wont accept the split rim. Well, they might fit but it specifically says "NOT for use on 2 piece Honda rims"
    1983 250R ~ 1984 125M ~ 1990 POWER WHEELS!! trike
    Opelousas, Louisiana
    1,337
    yeah i put split rims when the tire said not to and they did fine.
    1986 350X K&N filter, DG Krome Power exhaust
    1982 110 UNI filter, Cobra megaphone exhaust
    1982 honda 110 exhaust for sale, PM me.
    Jan 2005
    Slatington PA
    4,372
    A big disantvantage is they can leak at the seal in between rims. Thats why they stopped making them I think. I'd rather have the one piece jobs for sure.
    Mar 2005
    west PA
    77
    2-piece rims should always be tubed and/or RTV'd at the 2-piece o-ring (my old 110 had this and i did that, no tubed and never leaked)
    1970 International 1100D, dana60 rear, dana44 front, torqueflight727 auto, 345 v8, true dual glasspack exhaust, restored from field find, the only true orange binder, aka Tank
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by 70binder
    If you tube them though and get a flat, you can't repair it on the trail.......a tubeless you can.
    Jun 2003
    Anchorage/Homer, Alaska
    480
    The last set I mounted I used blue RTV sealant between each of the rim sides and a Bead Sealant on the tires. Worked good, no leaks.
    1985 ATC 250ES, Big Red
    1984 ATC 125M's, 1.5 of 'em
    1983 ATC 110, BLUE!
    1974 ATC 70 Pink?
    Jul 2004
    3,658
    I used window sealing silicone on mine.. and never had any problems with leaks.. no tube.
    Currently :
    Rittman, Ohio
    6,276
    Quote Originally Posted by MNRebel
    Comes down to this: Its common to hear " I got some one-piece rims to replace those two piece stock rims." Something you'll never hear is "I'm looking for some split rims to replace those cheapo one piece rims I've got".
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    Honda started with two piece rims. Once they figured out that one piece rims were better, they changed over to them. Never go back.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
