Results 1 to 15 of 21
Thread: DG exhaust system on a triz anyone
    Aug 2002
    NY
    2,652
    i just bought a brand new complete DG exhaust system for my tri-z. well it fits for crap. i had to use a banshee exhaust hanger on the silencer. it was the only one i had too. i still need one for the head pipe. the LRD exhaust i have fit stock mounting brackets and bolt holes!! my Phase Five exhaust fit the same as the LRD. anyone else have this problem? i like the sound and power it adds but hate the mounting points. i am selling my Z and want to keep the LRD,swingarm,and a few other hard to find parts. so seeing how DG was the only exhaust avaliable i when with that.but since i got the bike running better,(still scared about the carb) it is fast as hell. scary fast. well scary because the rear brakes dont work now lol. and trying to stop at top speeds with only half arse front brakes gets the hair up on my neck. well give me your thoughts about the DG thanks mike any help hints too
    Watertown, New York 13601
    3,382
    My DG didn't mount worth a **** either.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    Ithaca, NY
    2,596
    why dont you sell me a pipe mike??
    Haspin veteran '02, '03, '04, '05
    "Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
    RECOVERING Trikeaholic
    Mar 2003
    Kansas
    1,507
    as far as I can remember, me complete DG system bolted up fine, just like the stock setup.
    Aug 2002
    NY
    2,652
    hey holic i had that Phase Five for $150 but no one on 3ww wanted it. so i put it on ebay and sold it for $250. plus it was shipped to the UK. gone from the good ole USA forever!!!!!! money talks bull shitt walks.
    Bill X_R is offline Bill "The Finger" XR oo|oo Arm chair racerJust too addicted
    Feb 2003
    Cincinnati, OH
    672
    Quote Originally Posted by mike from long island
    i am selling my Z
    Dude you change your trikes more than I change my underoo's!
    86' 250 R
    02' DS 650
    03' Cannibal
    03' Haspin Vet
    04' Haspin Vet
    05' Haspin Vet
    Front royal, va
    2,186
    i got one of the last ones from dg, rubs the frame, holes dont line up, i used the banshee hanger too, its like they weld pieces togther with no jig or something, same goes for there grab bars and bumpers, the zilla i have, the holes dont line up either.... junk!
    Aug 2004
    Ab Canada
    4,368
    mine fits fine...but its an old old old one that was found at the scrap yard ....the flang (think thats the name...cirulare thing that gos to head?) was way to fing big for it tho....its being cut down and refited...
    1985 Tri-Z-
    3,382
    Quote Originally Posted by 03 ORANGE SHEE
    One of the last DG?? Their are plenty of new ones available.
    2006 YFZ 450
    asc180's Avatar
    asc180 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2002
    Howard City, MI
    209
    I had problem with my silencer too. The pipe fit fine. Made a bracket for it.
    Adam
    89 LT500R-
    85 250R- Project-
    85 250sx-
    83 185s
    80 act70
    Washingtons Crossing, Pa.
    2,977
    I had the same problem with my '86 framed Z, The rear stinger mounting hole was almost 3" off. I ended up using a piece of slotted angle iron to mount it properly. I had it powder coated and it ended up looking pretty sano.
    stevensj13's Avatar
    stevensj13 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2011
    Willow Springs, North Carolina, United States
    338
    I have an original DG from back in the day on my Z, fits like a glove although it did melt the rear portion of the front fender a little on the edge. Bummer too, that front fender is perfect!
    Mexico
    9,014
Name:	t post yamaha stephanie 051.jpg
ID:	133299I have two DG pipes. One fits like crap and the other like a glove. Go figure! The bad one seems to have too long an exaust flange, much longer that the snout on the cylinder. If you try to cut it to suit the pipe hits the frame. If you leave it as is there is all kinds of oil gushing out and I would imagine air getting pulled back into the cylinder as well. It also melted the stock fender. The second pipe has a much shorter snout and does not hit the frame. I purchased a automotive exaust gasket on ebay that some guy said was the the perfect fit for a Z and he was right. I added a 3rd spring mount on the lower right side of the cylinder (just like the left comes with) added that gasket, covered the snout with silicon and put it together using three new generic springs from Rocky Mountain ATV. I repaired my broken rubber chassis mounts with 4mm SS bolts, purchased an ultra cool silicon exaust joint on ebay and then cut my new rear fender to prevent it from melting, repacked the DG silencer and called it a day. Compaired to other aftermarket pipes I've mounted, I'd say that it went as well as it could have. So far no leaks.
    Mexico
    9,014
Name:	t post yamaha stephanie 055.jpg
ID:	133300Click image for larger version.
Name:	t post yamaha stephanie 060.jpg
ID:	133301Click image for larger version.
Name:	t post yamaha stephanie 085.jpg
    Here are a couple more. I cut the fender to suit after these were taken.
    Dec 2007
    Southwestern NY
    517
    I know this is an old thread, but I went to mount the Dg exhaust system on my wifes Tri-Z tonight...WHAT A PIECE OF !! Fits like...well... like you would expect anything from DG to fit! No matter what combo of pipe mounts and gaskets I tried, the silencer hit the frame...and the fenders, and stuck out at an angle, and stuck out too far.... Pipe seems to fit good with the stock Z mount, and it clears everything accept a very small porion of the front fender. The silencer simply looks like hell. SO, first I cut the junction flange off the silencer. Then I mounted the silencer directly to the rear silencer bolt hole on the sub-frame (instead of using the "hanger"), Got it nice and straight, then hacked 1 1/4" out of the mid pipe. Taking that bit out of the mid pipe, just after the connector, makes everything ALL better. Mid pipe no longer hits the frame or fender, and the silencer doesn't look like you cobled a blaster silencer on!LOL! I am gonna have a buddy tig it back together for me tomorrow. I would put some pics up, but my wife would kill me...
    SAY IT!!!!!
    85 1/2 Tri-Z - The Trail Bike w/Inverts
    85 Tri-Z - The wifes Bike
    85 Tri-Z - The MX/ICE Bike, 310 w/Inverts
    12 Tri-Shee - The Flat Track/TT Bike w/Inverts
    NYTRO - New York Trike Racing Outlaws - COME GIT SOME!
