Results 1 to 10 of 10
Thread: lt500r is powerful....
    dirtbike77 is offline At The Back Of The Pack Arm chair racerFirst time rider
    finally got the quadzilla up and runnin... the bike runs perfect throught all gears... i thought it had six gears, but it only has five gears...?
    i like the way it runs... but i want a lil more speed on top end....it has a 13th front sprocket on the front...
    should i go up on the front sprcket?
    lt500 mods
    .100 over
    dg pipe, silencer
    jetted carb
    20/11/10 tires in rear
    freeport, IL
    130
    If you want top end then yes, but i would throw on some 22's if you dont mind the look and its more like a 13 1/2 tooth.
    In Loving Memory of Jeff R. Beam
    In Memory I ride of you.
    "BEAM LIVES"
    1968-2004
    Mar 2003
    Barnesville,Ohio
    2,298
    i believe that the 87 quadzillas had 5 speeds and the 88-90 quadzillas had 6 speeds. i am not sure but i think. if you want more speed, then go up on the front sprocket size or down on the rear sprocket size. or both if you want a high speed. but as you gain top end speed, you will lose low end torque
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    Zillas are very fast...any pics???
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Anaheim
    1,270
    to 12 in the front u dont want a huge sprocke tin the back limiting ground clearence
    they are stock at 84??? i think
    adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    a-camp's Avatar
    a-camp is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Orange Co.
    420
    How big can you go in the front and still run a case saver??? My 13 is close.
    By the way what size on rear?
    Watertown, New York 13601
    3,382
    you need to get some pics of this beast!!
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    Front royal, va
    2,186
    my 87 500 is geared 12/41 stock is 13/40
    Feb 2008
    Pennsylvania
    I own a 1987 LT500R Quadzilla. It has a fatty exhaust, 40 over piston, 15,42 sprocket, 22/11/10 tires on the rear. Everything else is pretty much stock. I heard that they have cylinder head leaking problems. I just rebuilt mine because I didn't know the air cleaner disolved in the air box and I destroyed my piston and cylinder and had to get it bored 40 over. Obviously dirt got into the engine, probably the filter too, and put it out of comission for a while. Anyway, I never had any problems with the engine before, no head leaks, no transmission problems, no nothing and I rode it hard. The axel bearings went so I replaced them and the swing arm is next. I clocked my quad at exactly 96 miles and hour, and it might have had a little more to go, but the quad was too shakey and it isnt meant to go that fast anyway. I also heard that the 97 had a better transmission and had a higher top end. I raced Banshees, 450s, etc. and in the 1/8 mile it didnt do to good all the time , but in the quarter mile no one could keep up to me. I would literally pull away in third gear and say bye bye. The stock exhaust isnt really good and holds the quad back. If your a big guy, its perfect for you and handles pretty well. It will climb hills with ease barely reving it. I just though you people needed to know the facts.
    Aug 2004
    Phoenix
    1,226
    The LT500 is one bad motha! We have an 87 in the family with an LRD pipe, 39 pwk, durable axle, pep suspension, JL swingarm (rare), and a few other things I'm sure Im forgetting. If you fix the trouble areas on the 87 they are the ones to have because they put out the most power. The head gaskets do sometimes blow out if the compression is raised to high, o-ringing the head solves this problem. Also they have a tendancy to wallow out the cases where the main bearings sit, so the fix is to machine brass inserts in the cases.
    A great site for these is quadracerHQ.com. Dr. Q spends alot of time on these and makes the best pipe out there for the LT500.
    Here she sits waiting for the dunes this weekend..
    4 Strokes are NOT the wave of the future!
