22-11-10 inch tires on a 10x10 inch rim. is it safe?
for chrismas my girlfriend is going to get me a set on 10x10 inch rims for my big red, unless I tell her otherwise. I plan to put a 22-11-10 titan at 489's on these rims that I will take from my scrambler.
running a setup like this I have the following questions
1. am I more likely to blow a bead?
2.any other concerns I should have?
3.will a ten by ten make the rear end grip more making it harder to slide? (9x9 3-6 backspacing verse 10x10 4x6 back spacing)
the sooner I can get feenback the better because she wants to order soon so I will get them by christmas
1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
1985 honda es 250 big red.
85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
A trike to show up the modern utilitys
2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
