Results 1 to 13 of 13
Thread: measurement questions
    Nov 2004
    OH
    80
    I just have to ask ne ATC 250sx owners out there if they could take some measurements off of your front forks. But first of all I kneed to know if there is ne possible way to git a pair of 250 forks onto an ATC90. I need to know the length from top to bottem form side to side at the top (bolt patterns also) and at the bottem (tire sizing). If ne of u out there can give me some of those I would be very happy THANX
    Last edited by IceDude; 11-05-2004 at 10:52 PM. Reason: forgot the reason why i need these
    if you dont mind me asking,what are you doing with the measurments?
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Nov 2004
    OH
    80
    not at all. i am trying to get the biggest amount of power out of a 110 on a 90 frame but at the moment i can't hold on ne more because I have no suspention and it bounces so bad at these kinda speeds.
    Put a 200x front end on it....
    85 Honda 200X
    88 Honda CR 125
    Nov 2004
    OH
    80
    does the 200x have the same holes and everything
    the same holes as...?are you talking about the 90 that you have?
    85 Honda 200X
    88 Honda CR 125
    Nov 2004
    OH
    80
    yes I want to put some suspention on my 90 so that I can go faster w/o flipping
    go with the 200x front end,I think that you may have to cut the steering stop off to accomdate the larger 200x front end but I have seen it done before...
    85 Honda 200X
    88 Honda CR 125
    Nov 2004
    OH
    80
    i think I will have to consider that one. my main quest is to try and beat a bone stock 200 blaster with my 90 with many many mods.
    why not just buy a 200x frame(or a cheap 200x)and build it up with just a few mods and it would beat a stock blaster?parts for a 200x are easy to come by and are inexpensive...
    85 Honda 200X
    88 Honda CR 125
    Nov 2004
    OH
    80
    well I guess it is time to ebay it up some more. c what i can dig up and possible figuer out how to get a swing-arm and shock for some rear suspention to
    someone on the boards not too long ago had a bandit 110 racing frame with rear suspension on it...
    85 Honda 200X
    88 Honda CR 125
    Nov 2004
    OH
    80
    I really do want to try that. c I would get a 200 frame too but i can't do that at ne kind of races because then I would race in the 200x class no the 90 class ne more and I do not want to go there
