Dan, On all my Tecates there is just the 7 nuts, and the 3 smaller bolts in front(mine are all the same size). You also have to remove the upper motor mount. That is all that is holding the head down. Once the head is off you can remove the jug w/ the motor in the frame. Just push the piston down for extra clearance, but like jeb says watch the powervalve stuff. I have a manual here and Jeb also has 1 if I (we) can halp let us know. I can give you torque specs or other hidden info, if you need it feel free to ask.
Dont forget about the 1 lefthand thread on the powervalve actuator. It bit me pretty good when i had my rt side cover off. I don't know if you are going into the cluch cover or not but the little nut on the actuator assembly, under the little(2bolt) cover on the top of the rt side cover is LEFTHAND thread. Becarefull around it LOL.
IF I CAN BE OF HELP ASK AWAY
MIK6 / Mike
New England Ride 4/13
