Results 1 to 12 of 12
Thread: honda 250es, ozark 250, or bear tracker 250
    Oswego, IL
    1,858
    which one is the best out of all of them. i need some room i am 6'5''. will the 250 be enough? all i do is ride along trails, so top spead isnt a must have, also i want one that will last for ever. after reading the specsk im thinking of the ozark. o and all of these would be like 2002 or 2003. so im gettting a newer one. so if u have ever road or seen oany of these quads let me no what u think of them.
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    Apr 2003
    Bay Area CA.
    2,638
    i think youre too tall for all of them, im 5'11 and feel big on those 250 utes. i say get a bigger quad like a 400 utility.
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    Mar 2004
    457
    im 6'4" and i ride my dads recon every now and then and i dont think its too bad on room
    Oswego, IL
    1,858
    hows the power on it? and what year? you are talking about the 250 right?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Mar 2004
    457
    its a '02, the power isnt bad for being a 250, i know for a fact it blows away a same year bayou (dad has a bayou also). i think they are the perfect little machine. small enough to be light and nimble but still has plenty of low end grunt
    Aug 2004
    duluth MN
    114
    i would go with the honda not because it honda it just better and the ozarks are just to over rated
    Jun 2004
    geraldton, west australia
    1,068
    my freind has 3 2002 bear trackers and they are great atvs. they handle trails brilllaintly and can get some speed up to, they are also small enough to hit the tighter small trails. in the woods it can match my freinds 04 foreman 450es.
    LIVELOVERIDEDIE
    1981 Honda Atc 124R-Racer project
    2005 Giant STP 1- rollin' on 26's
    200xer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Recons are awesome 250cc machines, they are on the small side though. For a little more money, you can go for a Rancher which is an awesome wheeler which will last a very long time with little maintenance. We've had one for over 2 years with absolutely no problems.
    85 200x - Torn apart
    Washingtons Crossing, Pa.
    2,977
    You are too big for all of them ..... I second the Rancher - Although my friend George has a Rancher AT (push button manual shifter) and its an excellent machine - except for they have a wierd safety on the transmission where if it stalls out, you can't restart it unless its in neutral. The kicker is, you cant shift the machine unless its running - so you have to unpack the "manual" shifter wrench, hook it onto the tranny shaft, then ratchet the shifter until you find neutral.
    blodgett, oregon
    58
    I have a 1998 250 recon with a K&N filter and big gun pipe. I'm 6'3 and size wise, it fits me perfect. I only wish it had more power because I'm used to riding big bore dirtbikes. It has a good power for a 250 though. Dependancy wise, it is bullet proof. I was going up a rutty hill climb, got it sideways, and rolled it end over end more times than I can count. It bent the rear rack and rotated the handlebars back some, but when I got back down to it, the thing was still running. I finished the ride, and when I got home, rotated the bars back and bent the rack back into shape, and I was back in business, good as new.
    1990 Yamaha FZR600R
    1989 Honda NX250
    1983 HONDA ATC200E BIG RED
    1981 HONDA ATC200
    looking for atc70/90/110/125 in or around oregon WILL PAY CASH
    Jul 2006
    the bear tracker is just a newer timberwolf, so that right there should be able to tell you that its relaiable as that thing has been around since the early 90's
    a freind of mine has a recon 250 and its decent but dosnt have the power of the bear tracker, wich 2 neighbors next to me each have a timber wolf and the other has 2 new bear trackers, and Ive ridin them all and the bear tracker is alot faster than my buddies recon
    edit: I have no clue about the ozark, if it uses the same motor as the lt 250 than its the fasted of the bunch, but im unsure.
    Derek's Avatar
    Derek is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2006
    Boston NY
    164
    Go for the suzuki ozark lots of power there perfect quads. my dad has a ozark he loves it. I even plow the drive way with it. There the same engines as the ones in z250's there just geared diffrent. the honda is awsome too my friend has one he drives it like its a quadzilla he jumps it does hill climbes with it and wheeles what ever you do dont go with the bear tracker there made very cheaply.
    1985 Honda 200x
    - 30mm Carb
    - DG Exhaust
    - Rear Wheel Spacers
    - K & N Filter
