Results 1 to 3 of 3
Thread: Dim 350X headlights.
    May 2003
    54
    One of my headlights is brighter than the other. Neither one of them is very bright. I've cleaned the plugs at the light assembly. What else could it be? I need more light! Anyone ever put bigger/brighter lights on their X? Do you have pics? New bulbs and reflectors from honda are more expensive than laser lghts from Rockey Mountain ATV.com. Also anyone ever have their stator rewound for more output? Where did you have it done? Thanks for your help.
    86 350X, TC racing 425 (89mm) 12:1 piston, TC mid/top end cam, HD springs, High rev CDI, DG X-Cellerator stage III, Mikuni 36mm VM carb(250 main jet, still working on the idle jet), Airbox lid vents, and uni filter. Should be good for about 33-36HP to the rear wheels.
    GONE! Someone ripped me off!
    Apr 2003
    HARTFORD CT, USA
    478
    Are they dim even at high revs? ; high beam?
    'WHEN IN DOUBT.........GAS IT!'
    87 KXT250B2 Tecate
    86 ATC250ES BIG RED
    85 ATC350X
    85 ATC70
    'A FEW IN PARTS'
    May 2003
    54
    Yea, I think one of the reflectors is corroded inside and it may not be reflecting all of the light. But the color of the light is not very bright either, so I may have a combonation of problems. I think it was like $70 for two new reflectors and bulbs from Service Honda.
