Thread: Whats the difference between a 185 and a 185s
    May 2004
    SOuthen CALifonia
    138
    As the title says...just curiuos what the differences are between the two models.
    May 2002
    Dublin, Georgia
    635
    The 185 was slightly larger with larger tires and about 30 pounds heavier. I am sure there may be some other small differences, but therse are the big ones.
    Also 185 built in 1980, 185s built 1981-1983
    84 ATC200X--Wife rode it once, now I can't get it back.
    84 ATC250R--Trying to find piston for 300R kit.
    85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
    84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
    Bartlett TN
    3,083
    Also the later of the 185's had suspension in the front too.
    86-87 Tecate ROCK!
    May 2004
    SOuthen CALifonia
    138
    hmmmm....I was looking at bikebandit.com and saw an option for 185 and 185s in 1983....were both available?
    Or did the 185 disappear when the 185s came about?
    May 2003
    Houston, Texas
    2,409
    I don't think there is any difference. Both had 22x11x8 tires which were the standard size.
    I think someone was thinking of the 185s and the 200M or the 185s and the ATC 200.
    In 1982 the 185s was unchanged from its original version. By 1983 the model was given a front suspension package and some new tires.
    In 1984 the ATC 200s was born. It was just like the 1983 185s but it had 192cc and had a new rear fender/toolbox section in the rear.
    In 1985 the bike was unchanged. Honda did change the shift pattern however.
    In 1986 the bike was unchanged exept for new graphics.
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    May 2002
    Dublin, Georgia
    635
    1980 ATC185 has 25x12x9 an a slightly longer wheelbase, seat height is about the same. The 1981-1983 ATC185S had the 22x11x8 tires with the smaller frame. I have owned both and you can see the difference in size. No not confused with the 200. Look on the 1980 spec page here on 3WW.
