Results 1 to 15 of 18
Thread: backfiring?? what is causing this??
    Paul is offline First Time Rider Arm chair racerNew to the board
    Dec 2002
    96
    I start up my atc and it sounds like it backfires but it comes out the intake?? and it stall the trike.. what could be going on?? could the carb have anything to do with this at all??
    THanks
    225dx, My first atv and I am lovin it.
    Mar 2003
    Australia
    1,919
    Yeh we have an old xl250 trail bike that does that. I would also like to know why??? Kinda funny how it blows out of the intake.....
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Mar 2004
    Belton Texas
    132
    do u have an air filter on your trike and what type of gas u using because the same thing hapend to me and there was no air filter in the box and i just used panty hose
    three wheeling for life
    rides:
    83 honda atc 200 Sold for $400
    saving up for tecate 250R tri Z ao 350X
    Nov 2001
    B.C.
    933
    Intake backfiring tends to be a lean fuel situation, or a timing issue.
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Jan 2004
    selma
    186
    umm
    could that be from old or brokken reeds?
    Ride fast Ride Hard!
    Currently Own
    81' honda 250r Looking to sell maybe PM me
    Just Got my 84' honda 250r!
    81-83 185/185s currently SELLING! Pm me
    honda 200 198?
    check out my sites
    http://user.cavenet.com/compaqcoci
    http://www.f-d-rolls-bentley-parts.com or www.fdrbp.com for short!
    I live in Selma, Oregon 97538
    Mar 2004
    22
    Try adjusting your valve clearance. Woked for me.
    Mar 2004
    22
    lol forget above post.... i should have read the question first.
    May 2003
    336
    well my ytm did that check the guts of trailprotrailpro carb. mine was due to dryroptted floats and clogged up jets. hope this helps ya
    83 ytm200E SOLD & mid 80 honda 185s
    mywebsite
    http://www.geocities.com/raptor660rrules
    CPSC
    looking for:
    TRI-Z GOOD CONDITION
    several parts for an 83 ytm200E if ya need anything let me know.
    Jan 2004
    23
    my ytm200 did the exact same thing when I bought it....it sat a long time.
    I tore apart the carbs, took a little piece of wire and cleaned out every part...I found some tiny pieces of gook in there. then I adjusted the air screw and voila! now she purrs like a kitten!
    1983 Yamaha YTM200K Tri-moto
    Feb 2006
    Central Florida
    1,090
    this is happening to my 110 - i went with a k&n air filter attatched right at the back of the carb. I had a #92 main in it and could not get it lean enough and the next size down i went #85, it started poppin out the intake..
    im guessing it can backfire out the intake if it is rich or lean depending on how the engine is timed...
    quiet people seem intelligent
    Oct 2005
    Pennsylvania
    863
    Lean fuel burns at a faster rate, and is also easier to ignite, Any heat left over from the combustion cycle, can ignite a leasn mix before it actually travels down into the chamber.--Leaky valves, or worn out reeds can also do the same--but check the "SIMPLE" before the "SUBLIME"
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    bonkers_200s's Avatar
    bonkers_200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Middletown, NY
    393
    Check the simple indead, take a look at the needle in the throttle assembly that sits in the ventura. Make sure it's in the stock position for your machine, then play with it from there. I had the putters and back fires, a good cleaning and moving the needle stopped it for me.
    If you can't fix it with a , its an electrical problem.
    85 ATC 200s--Ratted out and not running at the moment
    86 ATC 200x--All stock other than the handle bars
    85 ATC 250es Big Red -- Just got new rubbers and she wants to ride!!
    04 Suzuki LTZ250 quadsport - It was a decent price and I'm a raging idiot.
    Jan 2004
    NJ
    1,646
    My yamaha did the same thing. Had to adjust the float. No problem now.
    3 CR500R's and counting. Do I really need 4???
    Do I really need 9 Tigers?
    Laegers ATC500R
    DO NOT send any thing to whats his face (dirt-face/crasher) here on the board. What a scum bag. He screwed (stole) money from me and screwed me on my ME360 and Hondaline 300R engine rebuilds.
    Apr 2006
    Crestview, Florida
    2,429
    what kind of trike are we talking about. if its a 4 stroke i would say timing problem. 2 sroke prolly the flywheel key.
    Feb 2006
    Central Florida
    1,090
    flywheel key is a good one!! I had mine messed up and couldnt get it to run for crap
    I take it that was a "NO", Unclediezel?
