Results 1 to 9 of 9
Thread: Smoke blowing out carb????
    Ok. I just got finished fixing the starter only to run into a new problem. When you turn the engine over it sputers and shoots little puffs of white smoke out of the back of the carb. Also when you run it, then check the plug the tip is covered in sut (I'm thinking sut cause you can wipe most of it off). While starting and it puffing smoke out the back, if you pull the plug it doesn't seem flooded or any thing because the plug doesn't smell like gas. It's a bit of a pain to get to start in the first place, but if you pull it behind my YTM225 then it'll start fine. What's up???? As always thanks fo the help guys
    My Rides:
    JUST BOUGHT 1984 250R
    1984 YTM225DXL owned since Feb. 2004 , 88 TRX300 4x4, 84 YT125 , 90 LTF250 , and 86 KLF300
    Also various other non running things takin up space
    Mar 2004
    Fond du lac,WI
    658
    hmmmmmmmm :?: im confused very odd :?
    I'm pretty confused myself
    My Rides:
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    Check the compression and adjust the valves. the symptom of not starting with the starter, but starting fine when pulled is indicitive of a weak or tweaked motor.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    is there a write up on adjusting the valves??? I still don't understand smoke blowing out the carb
    My Rides:
    i have seen smoke coming out of the carb only to the fact that a friend of mine thinks that if he cant pull start it he needs starting fluid. He has shot out lil puffs of smoke and some flames out of the carb but in Your case im confused.
    TheOlderFox's Avatar
    TheOlderFox is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2003
    Black Creek, WI
    299
    If you have smoke coming out of the carb, I would say your timing is off by just a little bit. This may not be as noticed when you are towing it to start becuase the engine is turning over faster. This could also cause the problem with ignition which is seen on the plug. Checking the valve gap could also help. If the gap is too small, the valves could be staying open longer than they should.
    Anyone know of a new project machine for me around Wisconsin?
    Jul 2003
    936
    sounds like timing :?
    Wanna race? ;-)
    85' Tecate (still looking for entire front brake asembly...)
    bonanza mini-bike
    if you cant ride with the big boys...put it back on the trailer
    Washingtons Crossing, Pa.
    2,977
    ... its either from an open intake valve or you have a hicup timing backfire.
