Originally Posted by
Punknurface
Have an 81 ATC200 that I rebuild the top end on. Engine runs great but the decompression lever just barely hits the rocker and isn't opening the valve at all for decompression. Before the rebuild it was working fine.
I replaced the piston/rings and put a new cam in.
Any help would be appreciated!
I recently had the same issue.
Adjust your valves again and make sure the engine is on TDC.
I thought I had the engine on TDC for the first adjustment but I did not and the decomp lever would not function.
Mine is now working as it should.
TRX450ER
ATC250SX
ATC350X
ATC110
ATC185S (Marlboro Red)
XR100R
CRF230F
Raptor 125
Breeze 125
Grizzly700
