Results 1 to 3 of 3
Thread: Compression Lever Issue
    Apr 2024
    Pataskala, Ohio
    4
    Hello,
    I have an 84 honda ATC200S.
    I have the cable connected to the compression lever but when i go to pull it the lever gets stuck in the up position and doesn't close. Could this be a bad spring or cable issue? Thanks!
    Apr 2014
    Edmond, KS
    2,580
    When it gets stuck open, check the cable to see if it's tight. if it's tight, the problem is likely in the pull start or the cable itself. If the cable isn't tight, the problem is probably internal. Tight doesn't mean that you can play a bluegrass song on it. Tight only means that there's tension on the cable.
    Apr 2024
    Pataskala, Ohio
    4
    I will check on that. Thank you so much for your response
