Thread: 185s tank and fenders on 200x
    Jul 2021
    Anthem Arizona
    44
    I have a nice 185s that I restored and have been riding for a few years but at the age of 56 I feel like I need some rear suspension. Since I have an very nice seat, tank and fenders I was wondering if I could just swap out the tank, fender and seat to an 83 200x roller I found cheap on fb marketplace. I know the tank bolts up different on the back side but the front uses the same black rubber cushions. I know the engine will bolt in and the wiring harness will work. The rear fenders may be another issue.
    Anyone have any input?
    az
    1,992
    I have to rearrange my cars tomorrow and will have access to the 185s and 200x I'll see if they are close
    don't forget if you make a autox you'll need a 200x intake, the 185s intake points the carb wrong
    And like MRCbuilds did on his X, the hydraulic master cylinder for the rear, he moved it onto the handlebars, so you don't have to modify a foot lever
    jim
    81 185s
    82 185s with 85 200s motor
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    projects coming along
    85 200s
    1982? 185s
    Jul 2021
    Anthem Arizona
    44
    Quote Originally Posted by Jim mac View Post
    jim
    I watched the episode, I don't really understand the rear brake pedal problem. I was under the impression that the brake pedal mount was on the 200x frame. I'm be looking out for your info on the fitment.
    az
    1,992
    brake pedal mounts and pivots around the kick starter boss which the pull start 185,200 motors don't have. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    az
    1,992
    okay the 185s the rear tank mount is in the center. the 200x mounts to the side and the tank mount bolts are studs where the tank hooks to. the distance between the front hooks and rear mount is longer on the 200x the 185 mounts won't stretch that far. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
