Thread: 1986 250SX head noise and jetting questions
    Aug 2023
    Washington
    5
    When idling and when you give it throttle it quite literally sounds like a lathe cutting metal (look it up!). The noise is quiet but noticeable if you listen. It is not obscenely loud but you can tell. It' s kind of concerning, but the thing has had a fair share of ride time and it has not gotten worse. I just really don't like it but have no time to investigate. Anyone have a clue what this could be to point me in the right direction when I one day get to look at it? Also has anyone put a K and N filter on their bike? I need to jet mine because the thing has no balls when you on the throttle and runs too rich, any advice is much appreciated
    6,811
    The most common noise on that model are worn out timing chains and guides .
    Aug 2023
    Washington
    5
    https://photos.app.goo.gl/GxLxN75bP68t9b6D9 heres a video of the noise, thinking about it maybe the cam chain could have totally worn through and is now rubbing on the tensioner? I guess the only way to know for sure is to take it apart... for now it is fine haha
    6,811
    Easy repair . Check out this thread . If you pull the tensioner just make sure your piston is at top dead center .
    https://www.3wheelerworld.com/showth...50sx+tensioner
