Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: 1981 250R resto-mod
    Feb 2024
    MN
    30
    1981 250R resto-mod
    Wanted to start a build thread on my project.
    I picked this bike up in tucson AZ. Was told it had a rebuilt 300. They tried to use a polaris piston in it, which was the wrong compression height. Needless to say it didnt run right.
    I decided to take the motor down and have the crank rebuilt. I did quite a bit of research and found a shop out in California that had a 300R Wossner 77mm piston, the only one left from a batch they had made. The 300 has some mild port work, and (the only one ive ever seen) a S&S Headers expansion chamber.
    After pulling the motor i stripped it to the frame and gave it a fresh coat of red. I cut the swinger apart and stretched it 3”.
    New seat cover, new plastic, PWK38.
    Planning to powdercoat much of the parts. Not going for show, but a nice rider. Trying to recreate an early race bike. I love the look of the Selvy 250R.
    Feb 2024
    MN
    30
    Feb 2024
    MN
    30
    Played around with some powder. Ive got Candy gold coming for the swinger and triples.
    One of the best tools ive purchased has been a Redline powdercoating gun!!
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    368
    Looks good! First time I have ever seen a supertrapp on a 2 stroke.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Feb 2024
    MN
    30
    Quote Originally Posted by Footy View Post
    Thanks, it was something i had on the shelf for an XT600 i used to own.
    Blasted and put the base coat of chrome on the swinger and triples.
    Feb 2024
    MN
    30
    It was pretty difficult to get an even coating of the translucent candy gold. Had to go pretty thick. Came out ok i think.
    Feb 2024
    MN
    30
    Fitting some parts while i wait to get my crank and 300 cylinder back from the machine shop.
    Jan 2024
    Amherst, NH
    67
    Looks good ! It’s amazing how much time goes into these projects when you have to do something to each & every part, but satisfying when it all starts to come together.
    Feb 2024
    MN
    30
    Quote Originally Posted by sjsst41 View Post
    I wasn’t planning on going quite this deep but every thing i took apart was trashed
    The shock was leaking a bit of oil around the bladder, cleaned it up and with a bit of grease around the sealing surface it held a nitrogen charge again, until the hose blew. Substituted a 10,000 psi rated grease gun whip for that.
    Forks stripped down for seals, of course all the teflons are trashed as well. Wheel bearings shot. Brakes missing. Polaris piston in a worn out 76.5 bore. Crank bearings toast. List goes on!
    Feb 2024
    MN
    30
    Found that a sprocket for a XL175 uses the same bolt pattern. JT sells a 38T under 30 bucks.
    Put the brake together.
    Feb 2024
    MN
    30
    Repaired a few cracks in the front wheel, mounted the sprocket and shock reservoir, and got the bottom end put together.
    Carthage NY 250r rules
    2,355
    Man I'm loving this build.
    250r rules
    Feb 2024
    MN
    30
    Rebuilt the forks and port matched the intake and exhaust adapters.
    Had some major issues with the paint i used. Taking way too long to dry. Giving it some heat..
    not me images
    Feb 2024
    MN
    30
    Paint is finally setting….Bottom end in. Top end on. Single shim out of a FL350 headgasket for a bit more compression. A bit more port matching to do on the intake. Paint fish eyed on the head so ill have to redo that.
    Fun seeing it come back together.
    Feb 2024
    MN
    30
    Got it fired up. Funny enough it still isn’t running properly. Sounds like a rev limiter past 1/4 or so throttle. I assume a CDI issue. If anyone has one i could try it would be greatly appreciated!
