Results 1 to 9 of 9
Thread: 200X trail rider build
    Nov 2023
    New Hampshire
    26
    Got my frame and parts back from powder coat last weekend. Started putting it together this week, it's a slow process as I'm building this out of a few bins of bolts and parts and a couple of junky rollers. The frame is gusseted as per recommendation here, lower cross tube moved about an inch forward to clear the drain plug on a 163FML, sleeved the front down tube and added some mounts for a battery, rectifier and starter relay. Still waiting on my wheels and battery holder to come back from powder. I mounted up a spare front yesterday and realized I have two 350X wheels and hubs (the wheel getting coated is the same as what I have), already powdered both hubs so I'll figure out how to make them fit. I'm planning to go to my shop tomorrow during this snow storm we're getting in New Hampshire so I can get a bit more done than an hour here and there. Hoping to be riding this thing when the trails open up in May, and save my back from the 200S.
ID:	271308Click image for larger version.
ID:	271309Click image for larger version.
ID:	271310Click image for larger version.
ID:	271311Click image for larger version.
ID:	271312Click image for larger version.
ID:	271313Click image for larger version.
    Scootertrash's Avatar
    In the sticks
    4,632
    What is a 163FML?
    What is a 163FML?
    It's a Chinese electric start motor. Good thing OP moved the tube to access the drain plug...
    Nov 2023
    New Hampshire
    26
    Yes it is a Chinese 200cc CG clone with electric start and reverse. I would prefer a Honda motor but I would also like to ride this thing in the spring, I'll be keeping an eye out for a CRF230 core engine if I can live without reverse.
    Anyway, got it on the ground on a set of spare wheels, moving right along but still plenty to do. I am planning to get an IMS gas tank and Maier scoops, but I'm on the fence about keeping the OE fenders I have. If I sell my 200S for a decent price soon I'll probably just get new Maier rear plastic and a second gen 200x front fender.
    Attached Thumbnails Attached Thumbnails 432510781_974619137611975_4185172523569774799_n.jpg
    Jan 2024
    Amherst, NH
    65
    It’s coming along nicely - looks good!
    Nov 2023
    New Hampshire
    26
    Picking away at it. Trails open in May here so I'm getting close to riding time.
    Update pictures attached, you can see my starter relay and rectifier mount and the swing down battery box under the back of the seat. Also had to make a carb adapter as the XR200 one I had was just a little short to reach the boot to the airbox. Working on the brake pedal now, similar to what oldskool is doing in his Big Red thread in here, bronze hat bushing and I'm going to use a piece of roll bar DOM tube to make the pivot. Also got some Holeshots for the back and got my gold powdered wheels on. Front wheel turned out to be a 350X so it's a little off center with the rotor lined up, I was going to turn the hub down a little to center it but looks like I might be able to get a 250R hub so I'll try that first. Waiting on some Honda parts, key cylinder and switch assembly so I can finish up the wiring and get the controls squared away.
    Attached Thumbnails Attached Thumbnails 437764212_2235461803471287_5596527685093561601_n.jpg   437258569_381994631501618_5987923803564736579_n.jpg   437750865_442886034929757_6006838251171026841_n.jpg   437744589_440398795209397_4853802797789561022_n.jpg   437737411_1064841534618783_6148311200705759830_n.jpg
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    334
    Looks good. Wish I had your fab skills and setup.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    HondaRidr's Avatar
    Salt Lake
    337
    Looking very nice so far!
    Nov 2023
    New Hampshire
    26
    I've had some issues uploading pics but I got the build done about a month ago. Still working out the little things, but got about 300 miles on it so far, got it road titled a couple of weeks ago. The engine turned out to have very short gearing, I went from a 12/40 to a 12/35 and now a 13/35 sprocket setup, it can cruise in 4th at about 30mph but still has more than enough low end for the tight trails. Reverse is pretty nice to have, but I could live without it.
    Attached Thumbnails Attached Thumbnails 441189609_755431243147613_4470593210469509962_n.jpg   441310867_1019241699715236_3116359028221793234_n.jpg
