Originally Posted by
ATC King
Yep, that be it.
It's real fun when they suddenly decide to let go while descending a step hill.
Even with good brakes the sudden absence of all engine braking is a pucker moment. A light throttle tap usually engages it, but nobody is thinking to tap the throttle when the trike unexpectedly freewheels downhill.
While replacing that, it's a good time to clean the centrifugal oil filter, which can have stuff really packed in there, needing to be physically removed. Besides the cover gasket, the oil cleaner gasket, the O-ring around the pump dowel (if I remember correctly), and the crankshaft end seal that goes in the cover, would be nice to have on hand in case they need replaced. By that, I mean they probably should be replace if there's no recent memory of doing it. Old rubber is unsafe.
I don't remember, but if there's a lock washer on the centrifugal clutch nut, it wouldn't be a bad idea to replace that too. They look like a flat washer that's a bit conical and have 'Outside' stamped on one side.
Thinking about it a bit more, because it's been a while for me too, the clutch basket may have to be removed. There may be a notch in it for the primary gear to slip past. I don't remember.
I need to replace the one way bearing on my '85 Big Red 250ES soon, while I am in there I also want to replace the clutch plates, apart from the cover gasket, do you know of any other parts I should order that would be good to replace while i'm in there?
1983 Honda ATC250R
1983 Honda ATC200E BIG RED (sold)
1984 Honda ATC200E BIG RED
1984 Honda ATC200X (sold)
1985 Honda ATC70 x 3
1985 Honda ATC250ES BIG RED
1988 Honda ATC250ES BIG RED
1995 Honda Frankentrike 50cc 2-stroke
2001 Honda TRX90
2004 Honda TRX300EX (sold)
2008 Honda TRX250TM
1976 Suzuki RV90M (sold)
1967 Vespa Primavera 125
1958 Massey Ferguson 35
