85 250sx No Spark, Replaced/Measured everything
Everything checks out. All the resistance at the CDI etc. Done all the test the service manual says to do, and replaced numerous parts.
One thing I have found is that while my pulse generator resistance is correct (300ohm ish), I don't get any voltage when I try to start it. The forum post here - http://www.3wheelerworld.com/archive.../t-185320.html says that you'll get .5ish volts when cranking?
Does that mean my pulse generator gap is bad? And if so, how do I fix that? I havent found much info at all on this.
Thanks
//ArrowChat Integreation Code
