Results 1 to 3 of 3
Thread: Yamaha 225 burns oil after warming up and fluctuates rpm
    Jun 2023
    Fort Wayne Indiana
    Help! I got this little beauty cheap for my grandkids. I've wrenched on bikes as a young man in a bike shop so I'm not completely ignorant of diagnostic procedures. I'm also not afraid to do a top end on this little guy. But I would love any input from those with more recent mechanical experience on these bikes. Going to do a leak down test soon. Already found the compression is only 90psi. And I'll squirt starter fluid around the carb mount to see if there are air leaks causing the rpm to rise irradically. Any thoughts that would help my grandkids use this before a teardown over this Summer? Also, is the centrifugal clutch hard to adjust? It slips terribly under any kind of load. I'm thinking I probably have to open that up and inspect it. Thanks! And yes I'm a newby to this forum.
    6,808
    Sounds like you need a top end service and the clutches replace . The centrifugal clutch has no adjustment if it’s slipping then it needs replaced , the main clutch has an adjustment .
    Jul 2019
    Shelton
    96
    check to make sure turning the handlebars is not pulling on the throttle cable making the rpms rise. 99 times out of 100 on ATVs and ATCs I've found smoking is due to piston and rings needing to be replaced, so just needs a top end refresh most likely.
