I need to do some land leveling at our ranch and wondering if my ATC 185s would be able to pull a DIY drag harrow around a bunch of sandy soil. Any of you guys tried this with your ATC?
I use a chain link fence style grade that’s weighted with my 250sx all the time . It definitely runs hotter but does the job just fine .
Thanks man.
Yo Stinker, how far are you from Laredo?
I used a 4’ wide 4” X 4” x 1/4” Angle Iron on a hitch and wired some concrete blocks to it. If I was gonna do it again, I would not make the angle iron any wider than the tires, because it gets caught on trees and things, and I would fabricate some block trays to it.
Send some photos of your progress.
It sucks to get old
Ranch is about an hour away from Laredo, it's in Hebbronville. Think I'm going to try and use some of the welded steel wire cattle panels I have sitting out there. Since it's really sandy I don't think it will need much weight on top of the panels. Might add some t-post to keep from bouncing around. I'll post pics next weekend when I give it a try.
Yeah there is, I have some multi-seal tire sealant in them so hopefully it helps.
I do about the same as shortline and El, but I use a gate from an old chain link fence style kennel with 2-4 6 inch concrete blocks spaced appropriately.
Thanks, waiting on the hitch I ordered to hopefully get here on time before I head out. If it doesn't arrive in time would there be any issues if I pulled it using the grab bar?
ETA on the hitch is Friday. Leaving Friday to the ranch in the evening so hopefully it arrives before then.
You can always tie a short strap around the carrier , tying it to the grab bar puts it at a bad angle an like El said it will be hard to control steering
