Should both lights be on whether the switch is on high or low? I get 1 light on low and the other light on High but never both. I do not think this is correct.
TRX450ER
ATC250SX
ATC350X
ATC110
ATC185S
XR100R
CRF230F
Raptor 125
Breeze 125
Grizzly700
Mine is both lights on either high or low beam, never a single light.
Sounds like some wires got flipped. That bulb has a low and high filament that use a certain color from the lighting switch and they are wired in parallel.
Or it may seem that one is on low and it's just the wrong bulb, it happens.
Ebay LED's blow in the case you thought about running them...
