1988 Final Gear Set Compatibility With 85-87 Final Drive Case?
Has anyone tried to see if the 1988 Final drive gear set PN 41310-HC4-300 will work in place of a 1985-87 gear set PN 41310-HA0-300. Visually from pictures they look the same to me and disassembly is almost identical for both. For $80 i think i might try the install and see if they are compatible. Link to 1988 Final drive on ebay...
https://www.ebay.com/itm/33364047390...2cde%7Ciid%3A1
[QUOTE=RamTex;1526075]Has anyone tried to see if the 1988 Final drive gear set PN 41310-HC4-300 will work in place of a 1985-87 gear set PN 41310-HA0-300. Visually from pictures they look the same to me and disassembly is almost identical for both. For $80 i think i might try the install and see if they are compatible. Link to 1988 Final drive on ebay...
Did this work for you? I have a 86 trx 250 and coming up with the same results and no one to confirm this will or will not work. Found on amazon:
https://www.amazon.ca/Differential-1...s%2C142&sr=8-1
//ArrowChat Integreation Code
