Results 31 to 45 of 48
Thread: ATC 250r New pipe!
  1. #31
    Las Vegas, NV.
    2,525
    Nice! LED makes a good looking pipe.
  2. #32
    Jun 2004
    Oregon
    1,784
    So I took it to the dunes and it ran pretty good for about 30minutes then it started sputtering on the top end. Checked the main jet it was a 185 pilot was 58 plug was black and wet.. So I dropped to a 175 52 and a new plug. Took it back out did the same thing ran much better for about 20 minutes then the top end started crapping out again, plug dark but dry.Dropped the needle from a dgh to a cej 3rd clip. Same thing but it’s improving a little. Not sure if I should drop another size in the main or what. Carlos says it might be something else going on.
    This trike is something else! Let me tell ya
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
  3. #33
    Jun 2004
    Oregon
    1,784
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
  4. #34
    Oct 2011
    Glamy's place
    98
    I've had similar symptoms with seemingly rich jetting, but no amount of jetting fixes it. I know that my Kawasaki ignitions aren't known for reliability, but 40 years old is a long time to live even for a Honda! Do you have a spare CDI or stator you could swap and try?
  5. #35
    Jun 2004
    Oregon
    1,784
    Quote Originally Posted by legacy51 View Post
    No extra cdi but I did drop to a 168m 52p and it seemed to cleaned up quite a bit. Dropped to a 50 and it was a bit lean so brought it back up to 52.
    During all this I bought a sphinx 300 from Arlan. Should have it in 5 weeks.
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
  6. #36
    Carthage NY 250r rules
    2,355
    Try a new coil.
    250r rules
  7. #37
    Jun 2004
    Oregon
    1,784
    Well this doesn’t look good. Wonder how long it’s been like this [emoji15]
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
  8. #38
    Jun 2004
    Oregon
    1,784
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
  9. #39
    Aug 2015
    Idaho
    847
    Your 250R looks like blast…nice work!
  10. #40
    Jun 2004
    Oregon
    1,784
    Quote Originally Posted by Jd110 View Post
    Thank you.
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
  11. #41
    Las Vegas, NV.
    2,525
    So did you get your tuning issue figured out from July 2024?
  12. #42
    Jun 2004
    Oregon
    1,784
    Nope still rich. But i literally just replaced the entire ignition and electrical put it all back to OEM. Got some V force 3 reeds as well going to try it next week. Now if that doesn’t fix the problem then I honestly have no freaking idea at this point what it could be. Runs great when the engine is cold but once it warms up it’s sputters and goes super rich. Hopefully replacing the electrical will take care of it.
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
  13. #43
    Jun 2004
    Oregon
    1,784
    I also purchased a Sphinx cylinder from Arlan. I’m just trying to get my current monstrosity figured out before I go to the next lol
    I’m very about this cylinder it’s going to be perfect for me I think.
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
  14. #44
    Las Vegas, NV.
    2,525
    Quote Originally Posted by Fox250R View Post
    Yeah, I'm a firm believer in changing only one thing at a time, but I realize that isn't always an option. Typically, it makes the troubleshooting process easier.
  15. #45
    Jun 2004
    Oregon
    1,784
    Completely agree, but I’m at the point to where I didn’t wanna sit there and test every component one at a time so I just changed everything the stater the coil, the wiring harness, the CDI and removed the other ignition that another shop here in Oregon installed.
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
