Results 1 to 3 of 3
Thread: How do I remove the exhaust pipe/muffler
    Aug 2021
    Yakima, Washington
    20
    Hi i recently acquired a "junk" atc 90 but after working on it, it fired and runs like a champ i had to cut a section of the exhaust out, (the part that runs under the engine), and I'm not sure how to remove the rear section of the muffler any help is appreciated!
    Jul 2021
    MT
    27
    should just slide out towards the front. I had one that had a hole and was caught on something, I just beat the hell out of it until it came out. a bolt or something was catching on the side and wouldn't allow it to slide out. torn a hole in the side of the muffler, but i didn't care because i was replacing it anyways.
    6,779
    Left side center bolt on the chain case cover has a long bolt that runs threw the muffler . Remove the skid plate and it should pull out .
    The hole in the middle of the muffler has a 6mm long bolt .
    https://www.partzilla.com/catalog/ho...c110-a/muffler
