Results 1 to 9 of 9
Thread: honda 2 piece split bolt together wheels
    Feb 2020
    madison
    69
    Question about you who have Honda machines with those 2 piece split rims that bolt together...do you have to run inner tubes in them for them to maintain air pressure?
    Secondly, Honda only had that style rims in 7 inch and 8 inch diameters? I have several of these wheels in decent shape and I had an interested buyer who wanted to know the size they were. Some 3 lug others 4 lug. I know the 70 had 7 inch and the best 90, 110, 125, 185 & 200 all had 8 inch.
    Thank you...
    Arkansas
    2,407
    There's an O-ring between the halves. No, they don't need tubes.
    I've been running the two piece wheels for decades and they hold air just as well as any other tubeless wheel. I like the way they look, but don't care too much for the placement of the valve stem. It's kind of hard to get to.
    Apr 2014
    Edmond, KS
    2,591
    They also made them in 9" diameter.
    Feb 2020
    madison
    69
    I was told by my dealer that once you take them apart and break the seal, you have to tube them. Thats why I have several 8 inch tubes here in my garage. I tried using duct tape to hold the center gasket but it leaked. Tried silicone on the gasket and it leaked. I even tried using an old inner tube cut to a gasket and it still leaked. The leak was slow, usually about a week and it would be flat.
    To make matters worse, no local power sports dealer will handle the split rims. They offered me new steel wheels at 50 bucks a piece. However the offset of the wheels will not work on the front. I think the bold pattern is 3/90 or 4/130.
    So I do all my tire stuff by myself in my garage. Had to break one down today to patch the tube.
    Arkansas
    2,407
    Any time I change a tire, or break them down, I use a new O-ring.
    With modern tire sealants, there's very seldom a reason to break one down except to replace the tire.
    There's no need to even try having a tire shop replace a tire on them. They don't have a drop center and any uneducated tire tech would potentially destroy one while trying to remove a tire with a machine. The halves have to be unbolted. There's no other way to do it.
    When bolting the halves back together, it needs to be done evenly, to prevent squirting out the O-ring to one side. There's a channel it's supposed to seal in.
    If the halves are good, and don't have rust pits, a new O-ring will seal them tight. I've never had a single problem with the OEM Honda two piece wheels sealing. Not one single problem, ever. That's the true true.
    Feb 2020
    madison
    69
    here is a photo of what my wheels are. I wish I knew the bolt pattern.
    Jun 2013
    Oceanside, CA.
    612
    Those are 4/130 bolt pattern. Use new metric size O-ring to seal. Check bolt holes for flatness.
    "HJ" Click image for larger version.
    ’84 YT60
    ’89 TRX250R (stock )
    ’90 LT500 Quadzilla
    Manheim, PA
    5,816
    Could just weld the halfs together and not worry about anything. Powder coat them and your golden. I did thst to a set.
    Jul 2021
    Edgewood, WA
    26
    I never had a leak problem myself with split rims. I just make sure the inside surface of the wheel is like brand new (no rust, no bumps, no holes, nice paint, etc) before reassembling it. If it isn't I clean, scrape, and paint. And use a new o-ring each time.
    Much easier and slicker than dealing with tubes, but that's just my .02.
    I may be old, but I still enjoy the feeling
    of the earth rotating beneath my wheels
