Results 1 to 14 of 14
Thread: Front tire options in 22x11-8
    Feb 2020
    madison
    69
    Hi all...
    I m curious to know what tire you like to run on the front of your 3 wheelers. I have personally tried many different tires and I found my favorite to be the BKT AT119. Looks like a turf tamer. 4 ply rated so not too easy to puncture but not so stiff to hurt your back over rough terrain. Only available from Pete's tire.
    Most of the knobby tires are undersized and easy to puncture (Cheng shin, Deestone) or have a flat tread profile and are a rear only (hole shot, razor)
    Kenda is phasing out the k284 front max which was my "go to" tire for many years so I have found the BKT AT119 to be the best suited option. I work at a tire store so I have access to almost anything I would ever need.
    Scootertrash's Avatar
    In the sticks
    4,638
    Feb 2021
    Dallas
    4
    I use these on all three tires on my 185S.
    Jul 2020
    Montana, USA
    121
    I use carlisle knotty tires on my 185s. 22×11-8
    Apr 2003
    Spanaway, WA
    1,240
    I have a Hi-Run knobby from TSC on the front of my 175 now. It's the same height/profile as the Carlisles on the rear. It isn't very round though, she shakes pretty good going down the road.
    Hoarder of the finest junk
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '84 TRX200 trike conversion.
    '87 Tecate 4
    Arkansas
    2,405
    Buying a couple of the Front Maxs' seems like a good future-proof idea. Just put them back, out of the sun and away from any ozone generating devices (brushed electric motors), and they'll be good for years.
    Those are possibly the best 22x11x8 front tires that will ever be available.
    I've never had too much trouble with punctures on the 2ply tires when using a quality tire sealant. It kind of depends on terrain though. I imagine somewhere with a bunch of slate or shale could be problematic, or in a clear cut, with a bunch of sapling stobs, though I've rode through many of those without a problem. We do have some nasty thorn patches here, where riding a 2ply without a sealant is likely to get a slow leak.
    A 2ply on a heavy or powerful trike would be more susceptible to punctures. I can see needing something more robust for those types of machines.
    Feb 2005
    Canada
    663
    Probably a little overkill but I've got an ITP Mudlite on the front of my 250. It's been on there for years and shows no sign of wear yet.
    1984 Honda 250R
    1985 ATC 250SX
    1985 Tri-Z 250
    1983 Honda 250R
    1986 Honda 350X
    1983 Yamaha Tri-Moto 175
    1983 Honda Big Red 200
    1981 Honda ATC 110
    Apr 2014
    Edmond, KS
    2,591
    Quote Originally Posted by Yamaha Tri-Moto View Post
    Well it has to touch the ground in order to wear.
    Apr 2009
    texas, San Antonio
    24
    That front max is PLUSH. Loved it
ID:	266791Click image for larger version.
    Apr 2009
    texas, San Antonio
    24
ID:	266793 fits tight. Maybe not good for suspended trikes
    Arkansas
    2,405
    It's a fatty, but fits fine on a 185S/200S.
    In the sticks
    4,638
    Quote Originally Posted by tree18is View Post
    Fits fine on my '84 200S
    Feb 2020
    madison
    69
    Anyone ever used the Carlisle Stryker as a front tire before? I got a special deal on a 22x11-8 single. $60
    The AT119 I usually get is 90 each plus 50 to ship each pair from Pete's tire. Finances are tight right now so I have a single tire and have a 125 that needs a front tire.
    Feb 2019
    Western NY
    50
    I tried the front max and found that it pushed more than turned. Switched to the Kenda K530 Pathfinder front and have had better grip in the corners.
    https://www.denniskirk.com/kenda/fro...prd/541193.sku
    1987 Honda 250SX
    1987 Honda 200X
