Results 1 to 8 of 8
Thread: ATC110 Ignition Coil Wiring
    Mar 2014
    Peoria
    23
    Hi! I have an ATC110 and I'm trying to use an aftermarket ignition coil on it. It has 2 male spade terminals on it (one green one black) Looks like on the bike I have 2 wires (one yellow one black) coming out of the stator and one wire coming from the ignition system. How would I go about wiring this up. Thanks!
    Nov 2015
    Davenport iowa
    1,144
    There is a wiring diagram on this site you should be able to access. The yellow is for your lights. So if you eliminate that for now and hook up the other two leads you should be able to test for spark.
    1974 original 90 X 2
    1974 Original 70.
    6,779
    What year 110 ? CDI or points model ?
    Mar 2014
    Peoria
    23
    I'm not sure what year it is but I opened up the cover and it's a points ignition. How do I hook up the other two leads? Sorry I don't fully understand where they would go. If one is a lighting output then there is only one wire to the stator and then two other wires that I think need to be hooked up
    6,779
    You need an original 6 volt coil with the capacitor attached to it , if your trying to use an aftermarket 12 coil it won’t work .
    This is the correct coil for a 79/80 Atc110 , seller has no clue what their selling lol but it’s the right one .
    Very good price , these usually go for crazy money .
    https://www.ebay.com/itm/GENUINE-HON...8AAOSwCOheAqfq
    Mar 2014
    Peoria
    23
    I tracked down the OEM one, any advice on how to wire this one?
    6,779
    Black wire from stator goes to the coil wire and the points wire also connects to that same coil wire . It’s that simple , if you still have the original harness ?
    Mar 2014
    Peoria
    23
    Yep I have it all just double checking. Thanks!
