Thread: 84 Kawasaki tecate 3 rear shock
    Apr 2013
    florida
    55
    Hi everyone can someone please help me and tell me what upgrade rear shock i can use please give me year make and moldel of the shock i can use and what mods i need to do to make it work....thats
    Jun 2009
    Leander TX
    2,217
    Banshee.
    Any year.
    Mounts upside down in Tecate.
    Does not work with some aftermarket swingarms.
    Have to enlarge the Tecate upper mount hole.
    Be sure to get the bolts/washers/seals with the shock.
    Length is slightly shorter than stock.
    Spring rate slightly higher than stock.
    I've used them on 3 different 85 T3s. I'm very happy with them.
    Should be no problem on the 84.
    I've bought them in nice shape for as little as $25 but that was a fluke.
    Plan on $75-$100.
    Arizona
    843
    Why not rebuild the stock shock? For 50 bucks you can get a new seal head, bumper, and oil. Rebuilding it yourself is not that hard, that way you save on labor.
    Apr 2013
    florida
    55
    Because im looking to upgrade the rear shock as i am putting 2005 cfr 450 shocks for the front
    Arizona
    843
    Quote Originally Posted by puckshot View Post
    Not sure a Banshee shock is going to be much of an "upgrade." The 2001 Raptor 660 shock also works with minor mods--larger mounting holes, I believe. It has a remote reservoir but it's a bit longer than the OEM shock.
    Apr 2013
    florida
    55
    I was looking at this fox 2.0 PODIUM RC2for a banshee for about 800 Click image for larger version.
