Thread: Atc 70 backfires
    Mar 2018
    Tulare, California
    21
    Atc 70 backfires
    So I am having trouble getting my 70 to run correctly. Here is what has been done to it.
    - Piston and ring replaced same as stock
    - Spangler atc 70 stock replacement carb installed
    - points have been adjusted to 0.35
    - ignition timing is correct
    - Carb has been cleaned a handful of times but nothing is ever dirty.
    - At first bike would only run on choke but that has been fixed, I have a aftermarket k&n filter on it. I’m not sure what else to look at as of right now. Bike will idle fine but when you go to give it gas it boggs out. I have been told it is the jets but I’ve never went down that road. Somebody please help!!!!!!!!!
    Dave8338's Avatar
    Dave8338 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2013
    Central MN
    378
    Sounds like it is running lean on the main jet, likely a result of the air filter change to a high-flow K&N. Have you oiled the filter and blotted off any excess oil? I assume it is backfiring through the exhaust? If not and it is through the intake, it is typically an ignition/timing issue. Plug gapped correctly? I'll admit to not being an ATC 70 expert however, all four-strokes run correctly with the same issues addressed.
    The Goal... All I Need Is The Time...
    6,779
    Trying to make a stock carburetor run with an open air filter will make the exact symptoms your describing .
    Can try a larger main jet or buy a factory air box set up .
    Their are at least 50 threads on this same atc70 topic .
    6,779
    Try choking the air filter with a rag and see if you can get it to rev up , if yes you’ll need a larger main jet .
