Results 1 to 15 of 17
Thread: What does the ply mean?>
    Jan 2004
    selma
    186
    is that how strond the side walls are? also can someone tell me what the three numbers on tires mean like..
    22x11x8
    i still kinda don't know and i like to know everything!
    Ride fast Ride Hard!
    Currently Own
    81' honda 250r Looking to sell maybe PM me
    Just Got my 84' honda 250r!
    81-83 185/185s currently SELLING! Pm me
    honda 200 198?
    check out my sites
    http://user.cavenet.com/compaqcoci
    http://www.f-d-rolls-bentley-parts.com or www.fdrbp.com for short!
    I live in Selma, Oregon 97538
    nitekrawler is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2003
    430
    22 How tall the tire is
    11 Width of tire
    8 Size of rim
    My front tires are 2 plys and rears are 6 ply. Stiffer, but less likely to get a puncture
    1982 Honda Atc 250r - Daughter's
    1982 Honda Atc 250r - Son's
    http://forums.atvconnection.com/photos.cfm/ID/1566/#TOP
    Mar 2003
    Barnesville,Ohio
    2,298
    it will probably say how many ply it is on the tire somewhere. exs: bias;2 ply; 4 ply; or 6 ply
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    Nov 2001
    B.C.
    933
    Ply refers to the layer material used in the construction of the tire, be it nylon or steel. Usually 2, 4, or 6 is the number of plys used in the building of an ATV tire carcass. The greater the number, the stiffer and greater the load capacity of the tire.
    Think plywood...layered wood...
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Don't be cheap! Go buy a manual!
    Jan 2004
    selma
    186
    ok. so i was reading the capacity load on some 2-plys and it was 330 pounds. i am about 250 and my bike has some weight to it also. i know it exceeds it. and if i do jumps which i do quite big ones... theres a chance they will blow out on me? :oops:
    Currently Own
    honda 200 198?
    check out my sites
    Jul 2003
    430
    Get a 4 ply then. Its in the middle 8) Personally, I went with 6 in the rear and 2 up front (like I said). I think 2ply just isnt enough for the rear. I am also 6'3 240 and all is good when I rarelly ride the kids Atc's
    Before, with the 2ply, I could see the tires, they would look low, now, nothing :!:
    bbechtel16 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Halifax, PA
    400
    Re: What does the ply mean?>
    Quote Originally Posted by compaqkoci
    If it's like automotive tires, the ply rating doesn't mean jack. Nowadays the ply rating is usually higher than the actual amount of plys in the tire. Basically the ply rating is supposed to be how strong the tire is compared to a tire of [older desgin?] that has that amount of plys. But often this isn't the case. If that didn't make sense let me know.
    -'86 ATC 250SX: No longer mine... Complete 350X front end, Corbra Megaphone system, 350X carb with UNI dual stage foam & outerwear bolted driectly up, Powroll/Rocky 260cc bore 10.5 to 1 compression piston.
    Jul 2003
    430
    Quote Originally Posted by bbechtel16
    It does mean something in automotive :-D Load range E tires (for towing) are usually 6-8 ply, stiffer side walls, which is 100% needed. Just as the 6ply tires on Atc now, thats why I don't notice the side walls flexing anymore as I did with the 2ply.
    Good luck
    Rittman, Ohio
    6,276
    Ply is number of layers but as bbechtel16 said, it doesnt mean jack, because there is no standard as to how thick "one ply" is. In other words a two ply, can be thicker than a 4 ply because its layers could possibly be thicker. It also has little to do with hardness. Obviously a thicker tire wil be harder than a thinner one made of the same rubber compound, but the main different in tire hardness is the rubber compound being used. An example is Carlisle and the reason I hate them is that they use a rock hard compound, and their tires are often much harder than tires that are thicker and/or have more plys. Maxis All Trax are a very thick, and a heavy tire, and they also give a soft ride, and they have a 2 ply rating, and Ive never put a hole in one. Ignore the ply rating.
    Jul 2003
    430
    Do this as I still disagree...SORRY. Go to pepboys ask for a load range E and a load range C tire (passenger tire). Each wil have different "ply" put them side-by-side and push in the center and tell me which is softer and which is harder and then tell me "ply" doesn't make a difference in hardness 8)
    OR
    Go look at a Chevy 2500 or a Ford 250 and look at the tires. See any "P" passenger tires? Why? You dont want any sidewall give, Hence, stiffer. Trust me, I am right
    OR
    Go to your local motorcycle dealer and ask for a 20x11x10 "2 ply" and a 20x11x10 "6 ply" and push in the center of the tire. Report back your findings. The "6 ply" is stiffer because it has less flex.
    This might help you see how the ply can effect stiffness
    http://www.csupomona.edu/~av/howthingswork/Howstuffworks%20How%20Tires%20Work.htm
    hondaatcvabeach is offline At The Back Of The Pack Arm chair racerFirst time rider
    virginia beach
    241
    He is right, ply dose make a differance, I know this because I have been an auto mec. for too long. Also The 22 ( 22-11-8) stands for how WIDE the tire is, 11 means the sidewall is 11% as tall as the with. and 8 is the rim size.
    1985 Honda 200x (200s motor)
    1984 Honda Big Red (200ES)
    1985 Honda 250SX
    1984 Kawasaki KLT 250
    1984 Honda 70 (Daughters)
    1981 Harley Davidson Roadster
    PROUD TO BE FROM THE LAND OF COTTON
    Check out my units website 3dvirginia.com
    *******GO DIXIE********
    virginia beach
    241
    Quote Originally Posted by nitekrawler
    11 Width of tire
    8 Size of rim
    22 is with
    11 means the sidewall is 11% tall as the with
    8 is rim size
    22 being the highth is a common mistake, mostly due to the fact that when people see a 22-11-8 compared to a 25-12-9 the 25 is bigger, The reason is you have a bigger % of highth. Think of it in car tires a 235-75-15 is much bigger than a 275-45-17.
    1985 Honda 250SX
    Rittman, Ohio
    6,276
    Quote Originally Posted by TimSr
    I dont think anything anybody said is a direct disagreement with what I said before.
    "Ply" is a number of layers, and is not a hardness rating. More layers, more often than not, means thicker, but not always. Thicker means less flex, than a thinner tire of the same compound. More "plys" almost as a rule for automtive tires, results in a stiffer tire because they are a lot more standard about the rubber compound they use, and lot less variety in design as very few are made for purposes other than pavement. The only common variance is the amount of weight you will put on it, and the easiest way to get a higher weight rating is thickness, and the best way to accomplish that in automotive tires is adding more layers. I dont disagree with that at all.
    ATV tires vary a lot more on their rubber compounds for different purposes, and terrain is a lot more of a deciding factor than weight. Granted soft ballon tires dont work well on heavy utilities, but among utility tires your not normally choosing a tire based on much much your girlfriend weighs who will be riding on the back. There are a lot more exceptions to the "ply" rules because of the wide range of compounds used so it very common to see tires with the same ply rating having major differences in flexibility, and not unusual to see tires with a lesser ply rating stiffer and or thicker than one of a higher ply rating.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by hondaatcvabeach
    Don't want to step on toes here. Just want to correct something.
    Auto tires and ATV tires are measured differently. If this was a car / truck tire ( or a few newer style atv tires ) then hondaatcvabeach would be right on the money. But that is not the case here.
    ATV tires go by Height x Width x Rim size. 22x11x8 comes to 22 inches tall, 11 inches wide, and 8 inch rim.
    Example, on a 22x11x8 tire: If the side wall was 11% tall as the width then the side wall would be only 2.42" tall. They measure way over that. But if you do a actual measurement you will see the atv tire measures close 11" wide ( different manufactures will be a little wider or narrower ).
    Here is a little cut out from a tire web site ( http://www.carlisletire.com/catalog/atv.pdf ):
    MTD Diameter: Height
    MTD Width: Tire Width
    MTD Rim Width: Rim width.
    I do know some of the newer ATV tires are going to the same style measuring as car & trucks. But 95 out of 100 ( estimate ) still use the old way ( Tire Height x Tire Width x Rim size ).
    Thanks
    Howdy
    virginia beach
    241
    I stand corected
    1985 Honda 250SX
