Results 1 to 13 of 13
Thread: Honda 185s main jet question
    Jul 2017
    USA, Wisconsin
    5
    Cool Honda 185s main jet question
    Hey guys, I was wondering what size main jets the Honda 185s takes. Mine has the stock 95 in it right know and bogs at full throttle due to the previous owner cutting out the spark arrestor. It runs perfect on half choke. Could someone tell me what the length, thread diameter, and head diameter of these jets are. I have looked all over eBay and find many jetting kits, none seem to mention the Keihin type PD carburetor which this trike uses. Any help would be greatly appreciated.
    Nov 2015
    Davenport iowa
    1,144
    Honda man go to jetsRus, they have a great chart for any kind of jet you need, you can determine your jet by the measurements you speak of thru their chart and then you just buy what ya need.. use it all the time.
    Jul 2017
    USA, Wisconsin
    5
    Quote Originally Posted by DAM shop View Post
    Thx you sir, if it runs perfect at half choke, any idea what number jet I should try, I was thinking of starting with about a 100 or so.
    May 2016
    OH Canada
    1,102
    Would cutting out the spark arrestor make "that" much of a difference(?)
    I would be making sure that carb is very clean first myself. Before guessing on a jet size. YMMV
    '83 200X
    Jul 2017
    USA, Wisconsin
    5
    Quote Originally Posted by Rob Canadian View Post
    You make a good point, I have cleaned this carb many times, but I might try an overhaul kit first.
    Nov 2015
    Davenport iowa
    1,144
    Quote Originally Posted by Honda.Man185s View Post
    Yep I agree with Rob on this one I think you have other issues besides a jet..
    Sent from my XT1650 using Tapatalk
    1974 original 90 X 2
    1974 Original 70.
    Nov 2015
    Davenport iowa
    1,144
    Have you checked your timing? What's your plug look like ? I think Rob is right on this one that the carb might be dirty.. not real familiar with the 185 but are you able to run an inline fuel filter on that?
    1974 Original 70.
    Jul 2017
    USA, Wisconsin
    5
    Timing is good, plug looks normal. I have cleaned the carb countless times. Have an in-line fuel filter and clean fuel. Seems to run awsome until you hold it wide open, wants to almost die, starving for fuel. I ordered a carb kit that should be in soon so I will try that next. Maybe somethings out of spec?
    Slidell, LA
    4,738
    Meaning, it’s always on half choke when running through the gears?
    Jul 2017
    USA, Wisconsin
    5
    Yes even idles perfect on half.
    Nov 2015
    Davenport iowa
    1,144
    You have a air filter in it right?
    Slidell, LA
    4,738
    If you need half choke when running through the gears it’s lean and you may have an air leak. Spray carb cleaner around the intake and the airbox connections while running and see if you notice a change in idle speed.
    Apr 2014
    Edmond, KS
    2,591
    Since you know that someone cut out your spark arrestor, That would probably be your main culprit. Yes, it really make your engine run that lean. Removing the spark arrestor removes quite a bit of restriction from your engine. Running with the choke halfway closed adds a restriction to the air flow, making your engine run better.
