Thread: Atc 70 SSR 125 motor swap
    Oct 2017
    Rhode Island United States
    4
    Hey guys,
    Any thoughts on the ssr 125 engines ? May be able to pick up a donor bike and was wondering if anyone has swapped these into a 70 before.
    Thanks,
    Matt
    Mar 2013
    Baldwin, Wi
    603
Name:	2013-05-05 19.17.17 (800x600).jpg
    This is mine with the SSR125 swap. I have been beating the tar out of this sense 2009 with no problems. Most fun you can have with your clothes on!
    85 Tri-z Basket Case
    Oct 2017
    4
    Lmfao, sounds good to me. How's the fitment ? The carb and intake looks offset so hopefully no problems there. Did you use a donor bike ? And how about the exhaust ? Was thinking I could make the one from the pit bike work. Thanks again !
    Mar 2013
    Baldwin, Wi
    603
    No fitment issue at all. Everything bolted up. You might have a gas tank clearance issue but I don't know as i run the pit bike tank. I just use the head pipe from the bike with no muffler(way to loud i hate it)because the donor bike didn't have one. I used the stock 70 exhaust but was way to restricted. Check out this web site for all the goodies you could possibly need.
    http://www.hondaatc70.com/home.html
    Nov 2014
    ATC 70 Gas tank to 22mm carb
    Which pipe off the atc 70 tank did you use for the carb connection?
