Page 4 of 6 FirstFirst ... 2 3 4 5 6 LastLast
Results 46 to 60 of 77
Thread: sand casting/aluminum-projects
  1. #46
    Aug 2016
    East of Worcester ma
    1,346
    Well not much accomplished today, made a 2" block with a 1/2" tongue that i'll stick in the reciever hitch on the truck. Figure i'll jack up the rear to see if/when it snaps off. Then slice open the 2" block to have a peek inside (towards the end of wk though).
ID:	246298 Click image for larger version.
ID:	246299 formed out of wood Click image for larger version.
    Edit-------
    Ok 1/2 ton chevy quadcab truck, just as rear wheels were going to leave the ground SNAP. Alot stronger than i would have thought. No bending first, it just let go....
    2x2 sawzall cut then sanded with 120 belt sander, added stain to darken up pockmarks last pic. I'd say not bad i guess
ID:	246332 Click image for larger version.
ID:	246333 Click image for larger version.
    One more edit: i need a couple new axle wrenches, i'm making it in plastic first so i can fine tune it a little. Maybe pour alum tomorrow(sunday) remember this is rough i gotta cut the far end off Click image for larger version.
    Shep
  2. #47
    Aug 2016
    1,346
    A little more pouring today, its not a real interesting piece but i think i learn something new each time. Anyway thanks for looking. And yes i could have bought an axle wrench but its the experience im going for here.
ID:	246407 Click image for larger version.
ID:	246408 Click image for larger version.
    Shep
    I could always turn it into a cool butter knife i guess if it fails.
  3. #48
    Aug 2016
    1,346
    Well here we go again, the wife wanted me to make a copy of the FOX trailer hitch for her. The plastic one i guess just doesn't do it for her. I have to have it done before noon so, and i had to modify the box a little, jeez she owes me bigtime...here's one pic- Click image for larger version.
ID:	246508. I will update shortly.Click image for larger version.
ID:	246510 gotta go set up the furnace now, ok she's gettin' hot Click image for larger version.
ID:	246511 done-just a little indent between his eyes(needed a vent/riser) there.Click image for larger version.
ID:	246512 Click image for larger version.
    Shep
  4. #49
    Aug 2016
    1,346
    Todays project- kinda would like a "sand rammer" but not going to spend the $ on a new one (500-700) rebuilt ones go for around 200.00
    Well if it fails i learned that yamabond "5" works great to coat clay parts, makes a nice hard shell!!! Click image for larger version.
    Now to make some alum-parts the pistol grip is going to be a tough one. Now i have to carry it over to the furnace which is about 75' away (i have to change that!!) Click image for larger version.
ID:	246721 Click image for larger version.
    Well here's a couple dirty pics-now to clean em' up Click image for larger version.
ID:	246728 Click image for larger version.
ID:	246729 Click image for larger version.
    Well its ugly but if it works thats all that matters...$12 harbor frieght palm nailer is a small investment i guess.
ID:	246760 edit- i had the kids play around w/it tonight and it hasn't self destructed yet.......
    Think i'll try a trizinger gas cap next, i've got the core setting up but not sure if my core sand is fine enough.Click image for larger version.
ID:	246776 3-days later-sand core failed...(need different sand)
    So i figured i'd make a mold of a stock tri-zinger cap, went to make some wax patterns(copies)- the top part of the cap is way too thin the wax won't even fill that area so molten alum wont either. Other than that the part came out great. Hmmm well i'm going to put that aside for now. Well maybe one more try.
ID:	246820 Click image for larger version.
    Shep
    Edit----
    Hopefully pouring today 10/14 but rain delay "at the moment" not the cap though.....
  5. #50
    Aug 2016
    1,346
    Here's todays pouring for those interested- just out of sand--Click image for larger version.
ID:	247029 Click image for larger version.
ID:	247030 Click image for larger version.
ID:	247031 Click image for larger version.
ID:	247032 Click image for larger version.
ID:	247033 Click image for larger version.
    86/87 200x heat shield
    --edit--
    Here's as far as (i'm) going with it (had it mounted- good fit) my son claimed it for his bike, but he wants to take it to school and use the shop buffing wheel to shine it up more.
    I'll take it off his bike in the future to make more if needed or wanted, just have to run it for a bit so theres no issues.
    I'm pretty sure the header temp is 300-500 (guess?) if it reached melting point (1350ish) i've got other issues!!!
    I looked around, theres a few older motorcycles that use a cast alum heat shield. This one is about 4mm thick so it is strong. Click image for larger version.
ID:	247061 Click image for larger version.
ID:	247062 Click image for larger version.
    Shep
  6. #51
    Mar 2004
    Eastvale, CA
    629
    Very cool. Back in the late 70's and early 80's in my high school metal shop class, I sand cast a pair of aluminum DeHandler shorty brake and clutch levers for my IT175 using Red Rider's plastic levers for the mold. From what I recall they came out pretty nice and worked great. I also have a brass Moto-X Fox belt buckle somewhere at home that I cast from a friend's real Fox buckle. Good times, "back in the day".
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
  7. #52
    Aug 2016
    1,346
    Quote Originally Posted by Mr. Sandman View Post
    I'm really liking this hobby. Went to my son's school open house last week, hung out with his metal shop teacher most of the time/he found out through (AJ) that i was doing this and he had lots of questions about it and wanted to maybe start doing it at home "the school would not allow a furnace in the shop" He has found some small foundry stuff around the shop so someone has done it there in the past.
    Find myself looking around the house for things to make just for the hell of it, and to learn more. I have to get back to my original projects though.
    I have to cast my kids hands this sunday/should be interesting...
    I actually have some red brass on order so i can try it out, i figure whats another 400 degrees.......(over alum)
    The only issue i'm having is i still have my 80's hair (not short) every once in a while i can smell hair burning, i guess its time for a haircut. My forhead has gotten bigger though over the yrs.
    Shep
  8. #53
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    ^^^ Shep, don't feel too bad. My forehead has gotten so big that it is now a fivehead.
  9. #54
    Scootertrash's Avatar
    In the sticks
    4,636
    Cool! I haven't done any sand casting since high school. Back in the day they would actually teach you how to work with your hands.
  10. #55
    Aug 2016
    1,346
    We ended up taking our son out of public school "he hated school, c student if he was lucky, same public school said he was a "slow learner" was in a special program they said that he needed. So we had our own specialist test him, the woman said that school was just using him for a # for state aide "they get extra funding from state for so many kids"
    Well very soon after we pulled him out.
    Now at a tech school- he's an honor roll student "top of his class" loves school now!!!
    Ok a little off topic but just wanted to point out that this new school teaches you to use your hands and actually learn more than what the state/gov "says to learn"
    Ok enough rambling- just a very proud dad here.
    Other son wants to be indiana jones or chef ramsey and will be going go a tech school as well....
    Have a great wk-end
    Shep
  11. #56
    Aug 2016
    1,346
    Had a nieces 1yr old birthday party this afternoon but my son and i still somehow managed to do one pour.
    Just finished in the dark not too fun. The hard part was him trying to keep his hand still for a half hour, well heres the
    Result its really cool, Click image for larger version.
ID:	247206 Click image for larger version.
ID:	247207 he's in the garage putting a file to the parting line scrap. Finished Click image for larger version.
    Thanks for looking-
    Shep
  12. #57
    Aug 2016
    1,346
    Here's my last casting for a couple wks, i didn't pour it hot enough you can see where the alum started thickening. I have to learn to slow down (have patience). But you get the idea, my phone keeps telling me its full, hope no-one cares i post my fails here. It stinks working on it for 2hrs w/this result Click image for larger version.
ID:	247228 Click image for larger version.
ID:	247229 Click image for larger version.
ID:	247230 Click image for larger version.
    86/87 200x keypad "well almost"
    Shep
  13. #58
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    Not failures, just learning as you go.
  14. #59
    Carthage NY 250r rules
    2,355
    I also remember doing casting and machine work in shop and ag class in school.The Junior High I started working at in the late 80s had a full metal,wood and leather shops with old lathes and a bunch of cool stuff. Now they do everything on computer.
    250r rules
  15. #60
    Mexico
    9,014
    I'd really like to see a Tri-Z clutch cover tried. Machining the water pump areas would be the most difficult part. Hell, If you could cast a "back half" of the Z cover and then weld the complex part of the OEM case to it in a little hold down fixture, that would probably work suprisingly well. Band saw OEM cases right infront of where the clutch housing area is, and weld it back to a reinforced area in the back. The fronts never break, its always the back around the kicker shafts. I'd be down to try that.
    I showed one of our casting suppliers a photo of a clutch cover and asked him for a quote last week.
    He said it would need to be injection cast and he could do the due for about $8,000 but that it wouldn't be worth running less than 10,000 pieces at a time.
    I didn't bother to ask what each part machined would cost, but I would guess they would be well under $50 bucks. So if anyone wants to invest $60,000 into Tri Z clutch covers let me know and I'll be happy to set you up. Myself, I think I'd try to carve one out of wood before investing in 10,000 pieces.
