Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 37
Thread: Husqvarna 394xp build/mod
    Blossvale NY
    4,563
    So as some of you know, I'm kind of into saws. Yeah I use them for work at home and at my job, but they have become another hobby of sorts for me as well. Besides making a little side money overhauling a few for a local tree service, I have been learning how to port them from some of the pros in the business. Cool side effect is that I'm learning 2-stroke porting theory. Now mind you, compared to wheelers, bikes, and sleds, a saw is basically a one-trick-pony. It's meant to run strong at WOT. Whereas bikes and such a broader power curve is more desirable and I can plainly see the difference in the port layout with bikes and such being much more sophisticated with boost ports, windowed pistons, and the need for reed and rotary valves. I am gaining enough knowledge and tooling that I am building enough confidence to port my own 250r cylinder in the not too distant future.. But I digress.
    I currently own all Husky's, a 346xp, 357xp (ported by me) 372xpw (75cc, ported by me) a 359 I built from a junk powerhead with a couple of simple mods, and finally got my mitts on a builder 394xp.
    I got this blown 394 powerhead in leau of cash offered to me for my labor overhauling a couple of saws for the tree service I mentioned above. Pics below starting with how it looked when I got it to how it currently sits...
    I went right through it from the crank bearings on up. The piston was scored pretty bad and there was piston material transferred onto the cylinder walls. These cylinders are nikisil plated and I learned that most often they can be cleaned right back up to good usable condition most times with simple sanding. My cylinder cleaned up good and I'm glad for that as nobody makes 394 spec cylinders any more, not even aftermarket. And to swap to a 395 top end while simple, involves swapping the whole intake tract over to 395 components as well.. Both saws are identical in most ways, but the intake tract is the biggest difference and adds several more parts to the list. Plus I wanted to maintain this saw as a true 394.
    Couple pics:
    Attached Thumbnails Attached Thumbnails IMG_20160310_150356099.jpg   IMG_20160310_150409845.jpg   IMG_20170119_031847184.jpg   IMG_20170214_040134019.jpg
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Blossvale NY
    4,563
    As the bottom end was coming together, I sent the cylinder to Shaun of Scarr Engineering to cut the squish band in the combustion chamber, cut the cylinder base (this is the typical mod done to raise compression) and raise my transfers for me to the correct height for the cylinder machine work. I opted to have this work farmed out because A: Being a 394 I wanted to mod this saw to the max this side of a true race saw and B: I do not (yet) have a lathe, Foredome drive and RA handpieces to be able to physically get in there and raise the transfers enough. I can do the exhaust and intake work myself with the tools I have already so I opted to do them myself.
    Shaun did a great job and if anyone out there wants to mod their big bore Husky (particularly 394 and 395) and are interested, just let me know and I will put you in touch with him.
    Couple pics of his and my cylinder work... First is his work on the transfers and squishband, second is my exhaust port. Forgot to snap a pic of the intake after I was done with it.. All said and done the cylinder is set at 98/116/80 for timing with 210 PSI compression... Stock these saws pull around 170-ish for compression. So yeah, definitely have to use the compression release when firing this beast up unles you want to replace copious amounts of starter components..
    Attached Thumbnails Attached Thumbnails 4503bc9d49a11d1c733b71e3a06256e5.jpg   IMG_20170120_031729915.jpg
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Blossvale NY
    4,563
    So I ended up getting a new cylinder cover for it as I like the HD Hi-top air filter setup better on these bigger saws. I also modified the muffler with an extra exhaust port to help it breath and dissipate heat more efficiently with these mods. After initial assembly, I figured out I had a problem in the low speed circuit of the carb that I was unable to remedy despite my best efforts. I swapped in a carb from another good running 394 I have access to in order to confirm and presto! This thing runs FIERCE! These saw carbs whoop me occasionally, they have such tiny fuel circuits that can be very difficult to clear. So now I am waiting on my new carb and a few other bits and pieces. I can't wait to get some runtime in the woods with this fire breather!
    Attached Thumbnails Attached Thumbnails IMG_20170325_153159337.jpg   IMG_20170325_153145918.jpg
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Mar 2009
    new england
    1,391
    Very cool. Now I will have to look for a project saw. I won't tear into my home saw yet. I learned long ago, don't tear apart your "daily driver" without a plan!
    NEPA
    7,049
    LOVE this thread,keep us posted!
    Carthage NY 250r rules
    2,355
    This is a cool thread. I like working on saws and weedwackers and other small two strokes aswell. I pull weed wackers ,push mowers and snowblowers from the dump metal scrap dumpster if they are complete and get them running again . I don't find many saws. I haven't bought a snowblower or pushmower in years. .One of my Uncles told me years ago that a lot of people buy a saw,lawnmower ,weedwacker ect,ect,ect use it once or twice store it away for couple years when they get it out to use again it wont start and they throw it out and buy another one.Usually they just need a carb cleaning or spark plug and fresh gas.
    250r rules
    Michigan UP
    1,005
    I'd like to start working on my Husy 2100 one day. It's from the 70's I believe, and 100cc's. I have a 56 inch bar on it, yes, 56 inches with an Alaskan 48 inch sawmill. It will cut through a three foot diameter pine log, 8 feet long in just about three minutes. I can't believe the torque it has, it don't matter how wide the log is that we cut, the saw never bogs down. We cut a bar top for my brothers garage that's 44 inches wide and 12 1/2 feet long, really nice piece of white pine with the natural edges left on it.
    Mar 2009
    new england
    1,391
    ^ post a pic of that beast
    Blossvale NY
    4,563
    Quote Originally Posted by briano View Post
    Yes Sir, 99cc of Swedish muscle! And you are correct, introduced in late 70's, discontinued 1987.
    My carb arrived in the mail today
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    kiser's Avatar
    Coshocton Ohio
    525
    I like it!! I have an old 066 I would like to warm up and this gives me motivation! Keep the info and pics coming! Post a video of it eating if you can!
    Blossvale NY
    4,563
    Absolutely will post a vid. I need to make one for my friends over on OPE Forum who have helped me out along the way with this build and I'll be sure and post it up here.
    OPE forum has alot of knowledgeable members and well reputed porters over there. Any of you guys looking to learn about saws, everything from where to source that hard to find part to full on porting and compression mods, I would encourage you to join up and check it out. I go by RIDE-RED 350r over there and have 10+ page build thread on this 394. Alot of good 394/395 info in that thread posted by some very knowledgeable people. http://opeforum.com/
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Blossvale NY
    4,563
    Well I swapped in my new carb and got a preliminary no-load tune dialed in. This thing is a beast! The new carb cured the issue and she now runs perfectly! Once I get a chance to go stuff it into some hard maple, I'll make a vid and post it up
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Blossvale NY
    4,563
    Quote Originally Posted by kiser View Post
    I'm not as well read up on my Creamsicles as I am with my Huskies but I do know that it is a beast of a popular large displacement saw. About the size of a 394/5, 90-95cc??
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Michigan UP
    1,005
    I will get a pic of it next time I go to my parent's house. It's in my dad's garage.
    Blossvale NY
    4,563
    Well, I got a chance to give my newly overhauled and modded 394 a real stress test today. Came into some large sugar maple, AKA "hard" maple. This stuff is harder and more dense than any oak we have around here, arguably toughest of any species native to this area. It will give any saw a real workout.
    So today I put the 36" bar on it and we did some noodling and blocking. I think it pulled it quite well. My brother was cutting with me using his ported 372xp X-Torq and let me tell ya, wood like this really shows the muscle the 394 has over the 372. Overall I am real pleased with how this beast came out.
    Here is a couple of vids and pics.
    https://www.youtube.com/watch?v=8aMMRjzRJ1I
    https://www.youtube.com/watch?v=v45qaqZSv7o
    Thinking my next overhaul/mod might be a 288xp or 390xp
    Attached Thumbnails Attached Thumbnails 0414171524.jpg   0414171525a.jpg   0414171523.jpg
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
