Results 1 to 10 of 10
Thread: 85' Big Red fuse location
    Jan 2008
    Willowbrook, IL
    856
    Think I blew a fuse when trying to hook up an LED yesterday. Went to try it out and when I turned the key, the neutral light went on then Out! Going to assume it's a fuse that is blown. Just not sure where it or they are located. Any help would be appreciated. Pictures even better. Or, just guide me in the right direction and what to look for. Thank you.
    85' Honda Big Red
    09' Yamaha YZ 250F
    2012 Polaris Sportsman 500 H.O.
    2015 Polaris RZR 570 LE/Trail Edition
    2017 Suzuki DR-Z400SM
    Jul 2003
    indiana
    892
    Main fuse on the red is in a little rubber boot type thing, forget what side of the frame, i believe it is zip tied to frame, wires run into it and back out same direction. It is not a fuse you can buy at hardware store, it's the old school wire type. If I remember correctly it's down by where the subframe branches off of the main frame. I'd send you a pic, but I sold mine. Hate that I did so too.
    Van down by the river
    3,874
    This fuse is hard to find. Let us know where you find one. It's located on the left side.
    R.I.P. John Swinehart
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
    Michigan
    1,144
    If it is that fuse in the back that is flat with a hook type on each end, let me know I have a couple of extra. I will go to my shop in the morning and see exactly where it is and take a picture of the spares I have. I got mine from Honda a couple of years ago, don't know if they are still available or not.
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    Jan 2008
    Willowbrook, IL
    856
    Thanks for the help so far. When I get home from work I'll check that black box. I located it this morning before I left for work but didn't have time to open it. Are there any other fuses to check? I thought that I read something about some by the headlight housing, where the wire for the headlight is housed. Is this true?
    85' Honda Big Red
    09' Yamaha YZ 250F
    Chopsaw is offline Just Too Addicted Arm chair racerJust too addicted
    May 2013
    St. Louis
    505
    There are fuses in the headlight assembly . Not sure what they do , but don't think it will keep you from running . Or is it just dash lights out ? If its just lights I would check in the headlight assembly , Extras in there as well . They are tube type . The wrench looking fuse is in the left side on the frame at the rear tire . I replaced mine with a modern fuse , ' fuse holder .
    Jan 2008
    Willowbrook, IL
    856
    Well after further investigation, I retraced my steps and it looks like the cable from the battery came loose just enough to lose connectivity. So, tightened it up and I'm back in business. Sorry for the trouble and your time, all for my simple error. However, I'd still like to thank you for your help. I learned a few things along the way. Appreciate your help and efforts.
    85' Honda Big Red
    09' Yamaha YZ 250F
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    321
    Quote Originally Posted by captainweezy View Post
    I just ordered 5 from partszilla. They have them in stock
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
    Jan 2008
    Willowbrook, IL
    856
    Everything checks out...
    Attached Thumbnails Attached Thumbnails 20170215_202125_resized.jpg   20170215_200033_resized.jpg   20170215_200058_resized.jpg   20170215_200023_resized.jpg
    85' Honda Big Red
    09' Yamaha YZ 250F
    May 2016
    OH Canada
    1,102
    Lights are on. Everybody is home.
    Good stuff it was a simple fix.
    '83 200X
