Page 16 of 20 FirstFirst ... 6 14 15 16 17 18 ... LastLast
Results 226 to 240 of 287
Thread: Time to see what all the Tecate hype is about?
  1. #226
    Jan 2014
    Prescott az
    723
    I'm sorry to hear that. If you could see them, you'd stand on the threshold, to the magical world of sensual delights, that most men dare not dream of.
    I switched to the desktop view on my phone and i can see them now. Very nice build you have there. I wish I had my tecate back. Another member on here bought mine so I still see pictures of it
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    86 tri z powervalved
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
  2. #227
    Las Vegas, NV.
    2,531
    Quote Originally Posted by 6spdls1z28 View Post
    Thank you. I'm not sure if that would torture, or comfort me, seeing someone else own my old ride.
  3. #228
    Jan 2014
    Prescott az
    723
    He restored it. It’s just a garage queen now. Trust me I didn’t want to sell it I had to. I rolled my wife’s bronco. She was still my girlfriend at the time. Sold it to buy her another one.
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
  4. #229
    Las Vegas, NV.
    2,531
    You did what you had to do to keep her happy.
  5. #230
    Las Vegas, NV.
    2,531
    It took a little bit longer than expected, but I managed to get the rear brakes bled last night. No fancy vacuum pump necessary here, just the old fashioned, tried & true, brake bleeding procedure:
    1. Put 8mm box wrench on bleed valve.
    2. Attach clear brake bleed hose to bleed valve.
    3. Put other end of brake bleed hose into a jar of brake fluid, and keep the loose end of hose submerged in brake fluid.
    4. Fill the reservoir with clean brake fluid.
    5. Depress the brake pedal.
    6. Crack open the bleed valve.
    7. Watch for air bubbles to come out of bleed valve.
    8. Close the bleed valve.
    9. Repeat steps 5-8, and step 4 as necessary, to ensure reservoir never runs dry and sucks in air, until brake pedal is no longer spongy, but firm.
    It is a small reservoir, but I must have refilled it at least 15 times, before I had gotten all of the air out of the line.
  6. #231
    Las Vegas, NV.
    2,531
    There's been a whole lot of progress on the Tecate as of late. Now that all of the handlebar controls are finalized, I was able to get the hacked-up, wiring harness, & connections all sorted out, and tidied up. The original, OEM kill switch had seen better days, so we found a nice billet kill switch to use instead. The headlight switch was missing altogether, and the lights were wired to be on continuously. To solve the lighting issue, I found the OEM lighting switch for a Kawasaki KLX 300 to be pretty close to the Tecate's, if not exact, and it was still available from Kawasaki. During the re-wiring process, the Tecate wiring diagram was a very nice asset to have. It guided me correctly throughout, and when it was all complete, we got spark! I also incorporated an '87 key switch, into the wiring harness at the same time.
    After tearing into the wiring harness, I still can't believe this thing ran when we got it. So many connections were just stripped wires, twisted together, and wrapped with electrical tape. Although at some point, the previous owner really stepped up their electrical game, and used crimped-together connections, and then proceeded to wrap those with electrical tape.
    We had no luck finding an aftermarket, aluminum grab bar for a 1986-87 Tecate, so we got an AC Racing, grab bar for a 200X/350X, and then modified it to fit. As an added benefit, this grab bar is longer, so I was able to extend it out as far as possible, which will compensate for the +4" longer swingarm, if we ever want, or need, to stand the bike up on it's tail.
    Attached Thumbnails Attached Thumbnails Controls1.jpg   Wiring Harnesses1.jpg   Grabbar1.jpg
  7. #232
    Mexico
    9,018
    That trike is gorgeous! Great work!!!
    It sucks to get old
  8. #233
    Las Vegas, NV.
    2,531
    When this build first started, one of the first things we purchased was a CEET tank skin, to cover up the typical, stained, original tank. Now that mr tecate has decided to go all in on this Tecate, he purchased a new Clarke gas tank. We had read quite a few complaints about Clarke's plastic gas caps breaking fairly quickly, and since mr tecate likes all things billet, he purchased a billet gas cap from Clarke as well. We knew about the dreaded blemish, from the Tecate tank mold at Clarke, but had also heard, that the blemish isn't too bad on the latest Tecate tanks from them. On this tank, the blemish is there, but honestly, it isn't too bad. I've definitely seen worse ones. It is still a shame that it is there at all though. The color, of the tank, matches the ORI front fender nicely, but is no where near as shiny. After snapping a few pics of the tank, mr tecate took it, so he could drop it off at his buddy's body shop, where it will get the blemish sanded out, and the tank polished up a bit.
  9. #234
    Arkansas
    2,447
    It's looking super nice.
    That was a good call on the cap.
    I think it was after the vent nipple broke on the second cap, I bought a billet one. Not from Clarke though, because if the cap that came with the tank wouldn't hold up better than that, it felt like a forced upsale. I don't remember ever having a OEM plastic cap break like that. I bought a Tusk brand one.
    There was a bit of concern about how it would play with the plastic tank threads, but after years of use, there's no damage. I don't get carried away with tightening it though.
  10. #235
    Las Vegas, NV.
    2,531
    Thanks ATC King. We did see the billet caps from Tusk, but they weren't available in green, and the Clarke ones were. Then, mr tecate decided to go bare aluminum instead of the green, because it didn't look like Clarke's green anodizing would match the green anodizing everywhere else on his Tecate.
  11. #236
    Las Vegas, NV.
    2,531
    Here's a pic of the dreaded Clarke, Tecate tank mold blemish, after sanding out the blemish, and lightly polishing the entire tank. We're pretty pleased with the outcome.
  12. #237
    Buffalo, NY
    1,994
    Beautiful build, you continue to out-do yourself. A group of us East Coasters are meeting up with our West Coast brethren in the dunes next week, you and Mr. Tecate should come out if you can
  13. #238
    Las Vegas, NV.
    2,531
    Thanks 86T3. Sounds fun, but this is still a ways from being completed, but we’re definitely getting closer. The new pipe is finally enroute!
  14. #239
    Las Vegas, NV.
    2,531
    Mr tecate finally received his new Dynoport pipe this afternoon. He brought it out tonight, so we could check it out, and see how well it fits. It's a little bit tight, against the rear of the cylinder/head area, but nothing a few well-placed spacers, on the exhaust hangers, won't cure. We wish the ceramic coating was a bit shinier, but all in all, we're pretty pleased with it. Some light buffing, with a micro-fiber towel, did seem to improve the sheen of the coating quite a bit, so we'll have to give that a try.
  15. #240
    Mexico
    9,018
    It’s tempting to want a chrome pipe on a ride like that, but long term that coating will outlast chrome by decades. This has got to be one of the best looking Tecate builds of all time
    It sucks to get old
