Results 1 to 8 of 8
Thread: Atc90 engine swap?
    vroomy's Avatar
    vroomy is offline At The Back Of The Pack Arm chair racerFirst time rider
    Australia
    174
    Atc90 engine swap?
    Has anyone here put a trx90 engine in an atc90? Just wondering if its possible and how much work involved. If not that motor any other options? Im thinking down this track as the performance atc90 stuff is crazy priced if you can find any!
    devore,ca
    1,016
    I put a china 110 engine in a ATC 70 and it was nearly just a bolt in. All the motor mounts lined up perfectly. I would assume that it would be the same for a ATC 90. The hardest part was coming up with a way to mount the battery, but even that wasn't bad.
    In the end I ended up with lights, electric start, and reverse.
    The china 110 quads are everywhere- cheap. The engines are Honda 90 clones. The quads themselves are crap, but the engines seem to be built pretty well.
    Oops,
    I just noticed your in Australia. The china quads may not be as abundant there. It would be worth a look though.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    vroomy's Avatar
    Australia
    174
    The atc70 and 90 have different engines unfortunately, i know that much. Just wondering how hard it is to modify for that style engine to fit the 90? As you said those motors are everywhere and have alot more power
    devore,ca
    1,016
    The 70 and 90 are different but based on the same design. They have a lot in common, including the way the mount to the trike.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
    Jan 2014
    Massachusetts USA
    782
    The TRX90 engines are built on a bottom end that is related to the 50/70cc engines, rather than the traditional atc90/trail90/110/125 bottom end. So a TRX90 engine doesn't bolt in to an atc90 or bigger. It can be adapted though, the same way people swap in the Chinese engines, which are all mostly copies of Honda 50/70 series engines.
    1985 Tri-Z 250
    1985 ATC250R
    vroomy's Avatar
    Australia
    174
    Is anyone making a kit to do the swap? Few issues i can already think of is chain alignment, front mount and footpegs......
    Nov 2016
    Lincoln NE
    37
    Dr ATV sells adapter brackets and foot peg adapters for the 50/70cc based pitbike engines to swap into a ct90/ct110. I'm sure there are others too. There are some pics of swapping a lifan 125 into a ct90 on dratv.com. Is the front mount necessary on the atc90? There isn't a front mount on the ct90 and the ct90 and atc90 mount to the frame the same way, correct?
    Since you're in Australia - here you go! https://www.ebay.com/itm/LIFAN-110cc...9ZyHFy&vxp=mtr
    Nov 2016
    Lincoln NE
    37
    Just realized I'm a year late on this post. I'm not used to seeing 2018 yet I guess...
    Was one of the top posts on a search I did looking for information on a 125 Lifan into atc90 swap. Sorry for bringing up a dead thread, but I do have a question: is the front engine mount necessary on the atc90/110? Did they really use it to stiffen the frame?
