Results 1 to 15 of 22
Thread: Tips for riding an ATC
    YBW is offline New to the board Arm chair racerNew to the board
    Jul 2016
    Buena Vista, VA
    41
    I searched google and the forum here and couldn't find anything substantial, but as a person new to the ATC scene I was thinking it might be good to have riding wisdom in one place (unless of course such a place already exists and I just haven't found it...) So far my observations are:
    -ATCs are much more nimble than ATVs
    -ATCs are faster than ATVs for their displacement (which makes sense given the reduction in weight)
    -Sharp maneuvers at high speeds are a recipe for disaster (for non-expert riders)
    That's about it. What other considerations are there? I have heard you lean into the turn and that you lean out of the turn, try to only use front brake and try to only use rear brake, etc. What about different conditions? Anything to know about mud or snow that isn't obvious? I'm kind of hoping there is a thread that I missed that has all the info, but if not some input would be greatly appreciated!
    Mar 2013
    Central PA
    2,362
    For a new rider I think one of the hardest things to get use to would be crossing over steep sloped terrains. Descending downhill and picking the right place to steer your front tire so you don't do a nosedive. I see my little brother make that mistake a lot. Riding on the side of a steeper hill. Stuff like that.
    Best way to learn is get out there and get some seat time. Learn the machines abilities. I've been riding a 200s my whole life. I know exactly how that machine is going to react if I hit this kind of bump, make this kind of turn, or most maneuvers for that matter. It's all about learning what the machine is capable of and pushing it to that limit. In a comfortable manner that is.
    TTown, Alabama, United States
    845
    They're unique in that the way you lean is entirely dependent on how fast you are going.
    I think its best to learn on a well maintained machine, good running machine, good tires, even pressure, tight bearings and straight axles all around. Hard to learn good sidehilling techniques if it dies on you or there's a lot of slack in the steering.
    I think Ghost hit the nail on the head. Knowing your machine is the single most important thing.
    Suicide Hill Survivor
    The rides:
    1981 ATC110
    1982 ATC185
    1983 ATC185s
    1984 ATC200es
    1985 ATC200x
    When the going gets tough, the tough get sideways
    Apr 2016
    Columbus, IN
    60
    like said above you have to put some more thought into crossing rough terrain, think about where its going to put each tire and lean accordingly or pick a different line. Usually its just easiest to try to take on any uphill/downhill transition straight on if possible.
    another thing is be aware of everything that might catch a rear tire, on an atv your front end is about as wide as your rear end so if the front will fit the rear will, on an ATC thats not the case. There have been several times that i have caught the rear tire of my 250sx on a big rock or tree root and if i hadnt been aware that they were there they could easily have thrown me over.
    one other thing is ruts on trails. on a dirtbike you can ride in a rut, on an atv you can have 2 tires in a rut and 2 out. on an ATC it can get a little weird sometimes. having just the front tire down in a rut puts the rear end high up and can make for interesting riding. Also if its slick and muddy out sometimes you might get the front tire and a rear tire pulled into a rut and you find yourself riding your ATC at an angle but going straight. something to me mindful of.
    "If you're gonna be dumb, you gotta be tough"
    ** 1986 Honda ATC 250SX - '86 250R forks - LED headlight - 250r gold wheels **
    Oct 2014
    tn
    110
    Agreed with all that has been said. When I got my 200x I hadn't been on an ATC in 15 yrs. Yes it takes getting used to seat time is all that will help. I also bot a set of extended hubs to make the rear 3in wider and it helps. Have fun, and being on two wheels sideways is fun when u learn how lol
    the only time I will be easy is when I'm killed by death
    Jul 2016
    Buena Vista, VA
    41
    Good stuff, I hadn't thought about ruts or getting the rear hung up on things. Yeah I haven't been brave enough to attempt any slopes, but I'm assuming you lean forward while going up and back while go down?
    May 2016
    OH Canada
    1,102
    Keep your feet on the pegs. Well unless you are powersliding and leaning into it. Just got back into riding trikes again after so many years. Always had a dirtybike.
    Seen and heard so many people about having crosshatches on the back of there legs from the rear tires (tyres)... But feet down and legs get sucked under the rear hoops... Not fun.
    Riding gear is important too. Like any machine. Body english is key. Shifting weight, learning.
    Jul 2012
    Seattle, Washington
    1,543
    Heres a helpful video thats been around for 30 years:
    https://youtu.be/xkrg3N4raXA
    Jul 2016
    Buena Vista, VA
    41
    Thanks Rob, I learned a little bit about keeping your feet on the pegs a couple of days ago! I didn't think of searching for videos, that may be some good stuff if I ever make it to that level of proficiency and am not riding a Big Red...
    Soutwestern PA
    2,040
    1. Never put your foot down.
    2. If you have to do an unplanned dismount, get off the high side and let the machine go.
    3. Use front and rear brakes together when you brake. That will instill muscle memory and put you in good practice for when (not if) an emergency occasion arises.
    4. Practice, practice, practice.
    845
    If you're riding one with with a pullstart, make sure its out of gear before you go to lean over and crack the throttle and pull it! Bad things happen fast.
    That's about all i've got...
    The rides:
    1981 ATC110
    1982 ATC185
    1983 ATC185s
    1984 ATC200es
    1985 ATC200x
    Oct 2016
    Fraser Valley, BC
    25
    Some general tips, some learnt the hard way.
    Handling:
    - Lean into the inside of your turns (lean left to turn left, right to turn right), the sharper the turn the harder the lean
    - Lean back when descending a slope, lean forward when ascending a slope
    - Stand up when moving over any rough terrain at any speed beyond a crawl, not only does this plant your feet to the pegs more firmly, it prevents the seat from hitting your butt and catapulting you
    - Always be aware of obstacles that will contact your back tires, failing to do this can also send you over the handlebars
    - Be gentle and gradual on the front brake, using the front brake for a hard emergency stop at any speed above third gear can send you over the handlebars
    - To turn sharply by spinning the tires lean far to the inside, begin turning the handlebars until you feel resistance, then give it extra throttle until you feel the tires begin to slide. The looser/wetter the terrain to easier it is to do this, DO NOT try this on concrete. The easiest way to practice this is in a gravel lot, if you feel the inside tire lift and the ATC begins to tilt immediately let off the throttle
    - If you get stuck in a mudhole and haven't stalled do not let off the throttle, keep your RPM up in the middle of the gear (1st or 2nd), stand up, and rock back/forth, side to side. If you're still stuck and you have a utility rack you can prop your feet up on it when rocking to put more of your weight directly on the back tires for traction.
    Starting:
    - Before pull starting, lift the vacuum release lever on the other side of the engine, this will greatly decrease the amount of times you have to rebuild your recoil after a snapped rope or failed knot
    - When electric starting, leave your headlight off, this saves a LOT of energy and grants you many more start attempts if you need them
    - If you're having trouble starting remember to double check your fuel tank switch position, key position, and ignition switch position
    - When cold starting have your choke pulled all of the way out, upon ignition listen to the idle speed, when the idle drops slowly push the choke in until it normalizes, wait, and repeat until choke is all of the way down
    - After a few failed starting attempts your spark plug is probably too wet with fuel to ignite, give it 5 minutes to dry off before trying again
    1982 Honda ATC200E Big Red
    1987 Chevrolet Scottsdale R10
    Tasmania Australia
    77
    https://www.youtube.com/watch?v=lGayYbLtd7A
    Another video
    Three wheeler stuff starts around 3:35 in.
    Sep 2014
    Oregon
    591
    Riding on trails with ruts from off road trucks can be a pain. I usually try to straddle them and drop my front tire in the rut, but it puts you at a weird angle. Also on rough trails practice going over small logs can be tough. And leaning to much on wet muddy hills. You can lose traction, or go up into a wheelie. Ask me how I know. Ha ha.
    Jul 2016
    Buena Vista, VA
    41
    Great stuff, these are the kind of tips I'm looking for. Tas Wheeler, the video you posted reminds me of a story my dad tells about a friend he would ride with when he was young:
    Friend-"Unless you are wiping out you aren't pushing yourself hard enough, your not learning!"
    My dad-"Well, can't I just stay at the level right before wiping out?"
    Let's just say the apple didn't fall far from the tree... I was impressed how much my confidence and handling improved just tearing around the yard though!
