Results 1 to 7 of 7
Thread: 1982 185s Tank restoration
    wellys88 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2015
    WA
    194
    Have 4 185'S Decided to start to redo them one by one, Started stripping one and redid the tank, It had 2 wholes which i brazed, I cleaned the rust from inside by putting a bot of chain in the tank along with a handfull of snall nuts and bolts, sealed cap and outlet and strapped pillows around it with ratchet straps and put it in dryer, after the majority of rust was removed i used vinegar to further clean the rust, alot of nasty came out after a few days soaking, I nutralised the vinegar with baking soda and distilled water, then i washed that out with soapy water then clear water, blew it out with a compressor then let it sit outside to dry for a few days, when done, I used redkote sealer, Click image for larger version.
    Nov 2015
    WA
    194
    Started to fill all the small dents with bondo and glazing puttyClick image for larger version.
ID:	235572Click image for larger version.
ID:	235573Click image for larger version.
    Nov 2015
    WA
    194
    Sanded bondo with 80grit them 180, then 320, then i gave it 3 coats of high build primerClick image for larger version.
ID:	235575Click image for larger version.
ID:	235576jClick image for larger version.
    Nov 2015
    WA
    194
    Filled low spots and began sanding again, started with 320, then 400,600 and 800 wet and dry, got it smoth and began to paint, i used Rustoleum sunrise red which i mixed with wetlook hardner and thinned it to put through the gunClick image for larger version.
ID:	235577Click image for larger version.
ID:	235578Click image for larger version.
ID:	235579Click image for larger version.
ID:	235580Click image for larger version.
ID:	235581 admidts my hard work this little guy decided to go for a paddle
    Nov 2015
    WA
    194
    And the finished with new reproduction decal set, set the tank on the big red just to see how it looked on a complete bikeClick image for larger version.
ID:	235582Click image for larger version.
    Nov 2015
    WA
    194
    Mar 2016
    Carbondale, IL
    43
    Man, that looks good. I just used a combination of JB Weld and solder to fill a couple holes on my tank and then coated the inside with POR-15. That stopped the leaks, but the outside of mine could still use some TLC.
