Results 1 to 3 of 3
Thread: Honda 2 wheel / Fat Cat conversion
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    732
    Hi, I have been toying with the idea of converting this spare trike frame/ parts bike into a 2 wheeler. The frame is from a 200ES, but with the shaft drive rear end cut off, and a chain drive rear end welded on, and a 185s motor. So I am not going to be hacking up a good frame.
    What is the best way to mount the jack shaft, and to tension the chain? How about the rear axle? What its the best thing to do with it, get a front hub assembly and weld on a flange for the sprocket? I am thinking of doing this as a hard tail, no suspension. Does anyone have any pictures of how they did theirs/modified the frame/set up driveline, etc? I am just looking for some ideas.
    Thanks
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
    Jun 2015
    Oklahoma
    732
    Bump....... Anyone?
    Da velder
    Feedback:
    JustEnough's Avatar
    JustEnough is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    Elk Grove, CA
    333
    There are a lot of threads on this site. Just use the search with fatcat or fat cat. Here is one that should interest you:
    http://www.3wheelerworld.com/showthr...ghlight=fatcat
