Is anyone running 22 inch rear tires on their 85-86 ATC250R? It is well past time to replace the rubber, but I wanted some feedback on handling/stability before going up in size. Thanks.
I wouldn't run anything larger than 20'
It will just cause it to bog and be out of tune. Stick with what works.
"Roll on 3"
RIP Ol' Deuce
"Long Live the ATC"Building: ATCr125xRiding: ATC200sx"I am not a mechanic, mechanics get paid for this. I do it because I enjoy it."
My friends 86R has 22 in. Dunlap tires with the OEM pattern. Think they are off a 350X.
He doesn't like it. He describes the ride as not as stable.
Run these-
http://www.hpcheetahtires.com/tires.html
Mine came with 22" they worked but the 20s I have on now are much more enjoyable
Mixing gas and haulin' ass
1984 ATC 70 x2
1985 ATC 250R-Ported/Polished, PWK 39mm, V-force 3's, Outerwears air box lid, FMF fatty with DG silencer, DWT wheels, LSR +4 axle, all black plastics
1985 ATC 250R-stock
Thanks for the replies. Since I had never tried 22" tires on it, I was hoping to get feedback from people that had. I guess I will stick with 20" tires. I DO like those Cheetah tires. I loved the OEM Dunlops that came with my 250R.
I ran 22" Stock 300EX tires on my 250R for a while. It was fantastic on really rough and rocky trails as they aided in softening the ride. The downfall is it raises the center of gravity a bit. For me, I liked it, but for woods riding ONLY. I prefer 18" on tracks or anyplace else besides trails.
I have 22's for snow but they're too big and heavy otherwise.
__________________
'85 ATC250R
.030 Over Wiseco
FMF Pipe/Answer silencer
36PJ Keihin
K&N
Boyesen reeds
Magura hydraulic clutch
Roost Boost
MSR bars
OMF swingarm skid
ITP Beadlocks
Three Wheelin' Since '84
Maybe 24" spinners would be your style. Much smaller than the people suggesting 20' (!) tires. I don't think they even make 20 foot diameter tires.
http://www.ritchiespecs.com/specific...modelid=107710
Selected Dimensions
Dimensions
A. Overall Length 30.5 ft in 9296 mm
B. Overall Width 13.3 ft in 4039 mm
C. Overall Height 11.6 ft in 3543 mm
D. Wheelbase 13.8 ft in 4191 mm
E. Ground Clearance 2.1 ft in 635 mm
F. Dump Height 28.3 ft in 8636 mm
G. Dump Ground Clearance 2.1 ft in 635 mm
Dump
H. Dump Angle 60 degrees
Specification
Engine
Make Detroit Diesel
Model 16V-71N
Gross Power 608 hp 453.4 kw
Net Power 576 hp 429.5 kw
Power Measured @ 2100 rpm
Displacement 1136 cu in 18.6 L
Torque Measured @ 1600 rpm
Max Torque 1600 lb ft 2169.3 Nm
Aspiration Natural
Number of Cylinders 16
Operational
Fuel Capacity 185 gal 700.3 L
Cooling System Fluid Capacity 43 gal 162.8 L
Engine Oil Capacity 16 gal 60.6 L
Steering System Fluid Capacity 26 gal 98.4 L
Brake/Hoist System Fluid Capacity 39 gal 147.6 L
Hydraulic System Fluid Capacity 65 gal 246.1 L
Operating Voltage 24 V
Alternator Supplied Amperage 50 amps
Tire Size 21.00-35 (32 PR) E-3
Damn still using non turbo v16s huh guess that's why those trucks are always hauling ass around the quarry
I like how you went out of your way to find and post the specs on a Euclid. But it says the truck is only 11 ft tall. That is probably an aspect ratio or sidewall height on the tire.
Edit: 20 is the section width, I think. Tire sizes are confusing.
