Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 37
Thread: Input on 1986 200x
    250ES5984's Avatar
    250ES5984 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2011
    Alabama
    199
    Input on 1986 200x
    Going to pick this jewel up tomorrow. He says that it smokes when it gets hot. I'm thinking that it would be rings but I'm no mechanic. Pros and cons? I know the '86s are 6 speed and they're a little different. Any input is appreciated. Thanks!Click image for larger version.
ID:	230966Click image for larger version.
ID:	230967Click image for larger version.
ID:	230968Click image for larger version.
ID:	230969Click image for larger version.
ID:	230970Click image for larger version.
    Jan 2014
    La
    1,062
    Depending on the price the bike looks to be in good shape. I would snatch it up even with the motor problems.
    Sent from my KFFOWI using Tapatalk
    Mar 2007
    Texas
    5,045
    I would get it and rebuild the top end. figure about $400-$600 to do it right over what you spend on the trike.
    ________________
    https://www.mikesatvfix.com
    The handling and feeling of every part of the 86/87 is superior. Way too many changes to list from the 1st generation.
    The headlight alone fetches 250$.
    The 1st gens can be built to make more power but I'll take my 87 over that anyday.....
    TTown, Alabama, United States
    845
    Had my eye on this one for a while, rare find around these parts! Get it!
    Suicide Hill Survivor
    The rides:
    1981 ATC110
    1982 ATC185
    1983 ATC185s
    1984 ATC200es
    1985 ATC200x
    rustyhondas's Avatar
    rustyhondas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    florida
    316
    That thing is nice
    86 atc 250r
    85 atc 70
    84 atc 200s
    05 650 rincon
    06 400at rancher
    93 lt80
    02 kx65
    Jul 2015
    Fredneck Md
    94
    I have an 86 and 87. Excellent handling trikes. Cosmetic parts can get a little pricey ,but that one appears to be all there. Smoking or not I'd snatch it up and fix it. You won't be sorry.
    Crazyktmmatt is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2014
    Idaho
    237
    I bought a 86 for $300- had a bent intake valve. It already had a wiseco piston in it come to find out. I did another jug for it since it had a couple pits in it I didnt like. Runs good has more power then my first gens on the bottom end. My 83 feels faster on the top with just a supertrapp. I need to re put exhaust on the 86 since i sold the DG off it.
    The 86 is my favorite rider of all my 25 bikes lol
    200x - I think I have 7 of em?
    10 70's
    3 350x's
    Tri Z
    225
    kxt
    and the 90 110 125m that I need to get rid of.
    YT175 with rear suspension sold
    200es- SOLD !!!!!!
    250ES5984's Avatar
    Oct 2011
    Alabama
    199
    Well, I got it. 1000 bucks wouldn't bad I don't think. Has a small oil leak, don't know yet if it's from the head ot the right case. The tank is absolutely spotless on the inside. It's actually surprising how clean it is. It has aftermarket fenders on it, but that's no problem.
    Aftermarket exhaust is probably gonna be next. Are they somewhat easy to find?
    The lovely carb is probably gonna have to be replaced. It won't run unless the choke is on, and the choke won't return unless I push the small metal piece down with my finger. Is that a common problem?
    The guy somewhat rigged the kicker and it won't click back in the closed position. If anyone has an extra, let me know.
    Brake pedal is bent pretty bad. Probably going to need one of those too. Rear brake pads from eBay or somewhere?
    Need a rear grab bar, prm possibly.
    On the upside, it has 3 nearly new tires, and two aluminum wheels, may be douglas, I don't know yet. It also came with the tail light, so I'll be putting it on someday soon.
    I'll upload pics later, my phone it being stubborn. Thanks for all the replies and input!!
    Chandler.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    Jul 2014
    Idaho
    237
    Dg exhaust is easy to get for em. Dumb loud tho.
    I have a brake pedal for one.
    Sounds like the plastic lever is missing. Ive seen 200es ones on ebay
    The prm is nice on 86
    10 70's
    3 350x's
    Tri Z
    225
    kxt
    200es- SOLD !!!!!!
    250ES5984's Avatar
    Oct 2011
    Alabama
    199
    Matt, the plastic lever is there, but when I push the choke off, the metal rotating piece in the carb won't rebound.
    Dec 2014
    Hoffman Minnesota
    135
    Quote Originally Posted by 250ES5984 View Post
    That sounds like your missing the spring or the spring is broken/slipped on the outside of the carb. Does the choke move easily? Is there a spring on the outside of the carb?
    1982 big red
    1974 atc 90
    Life is hard, but its harder if you're stupid - John Wayne
    250ES5984's Avatar
    Oct 2011
    Alabama
    199
    Quote Originally Posted by thcowboy View Post
    Yes, it moves freely, but no there's no spring
    Jul 2013
    USA
    737
    The stock exhaust is better than the dg, unless you race. In my opinion dg gives you a smidge more power because you have to use bigger carb jets. I agree with the above post about the excessive noise of the dg. My dg 86x can be heard well from a mile away.
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    Quote Originally Posted by Crazyktmmatt View Post
    What kind of grab bar is that? Where'd you get it?
    Sent from my SM-G935V using Tapatalk
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
