Hondabond, 3bond and Yamabond are all for no called for "no gasket situations". Be aware of some housings like the 83-85 200X kicker gear housing that MUST have a gasket for the correct clearance or they bind.
Every head and cylinder and case base I tear down, I lightly use a countersink on all the holes.
Then I use a hard stone and WD40 to remove any imperfections in the mating surfaces. You can watch them disappear.
Wipe em down with brake cleaner, whatever and I light ly coat each side. Let it set up a few minutes and put them together. I actually put all the bolts in very lightly (with grease on them and my dowel pins too) , and the next day crank them torqued down. Clean hands, bolts and a clean bench.
I haven't touched RTV in 15 years, (RTV makes me run away!!).
Never have had a leak yet......
