I agree all good stuff you should try. For me: combinations of hot then cold, torch for a minute or two, splash room temp water, it will evaporate quickly, spray with PB. Let sit. Hammer /drift. Heat, water, turn left, turn right. This has worked for me many times. If you have access to a good heat gun that maybe just as good as torch. Torch is hard to beat but gun may be safer in some cases.
79 110
83 185S
84 250R
3x85 Big Reds
85 200X
85 ATC 70
85 Tri-Zinger
86 200x
86 TRX 125
87 TRX 250
89 TRX 300
98 TRX 450S
03 TRX 350
5 Foreman 500 4x4's
You can never have enough! ATC250ES is still the best!
