Currently going through a complete service on my YTM200K, adjusting valves, cam chain, clutch, carb, brakes, etc...
I pulled the carb off the bike, gave it a thorough cleaning and am checking to make sure everything is in proper spec's.
According to the manual, the float height should be 21.5mm and the fuel level in the bowl should be 3mm from the carb body.
When I checked my float level, it seemed to be on the higher side... but due to the the angle of the carb, the fuel level is higher on the front than back.
So should I be checking it in the middle? front? back?
Here's a picture of the level initially:
I pulled the bowl and tried to see the point at which the needle was fully seated, looked to be around 19mm from the float to carb body.
I adjusted the tab on the float to close the needle around 21mm. Here's how it looks now:
I'm wondering if that's going to be too low now? When I got the bike it started and ran fine, but I did feel that it was a little sluggish down low. Sometimes if you quickly gave it full throttle off the start it would hesitate, which I've heard can be a symptom of running lean or rich...
On the topic of jetting, once I get the floats dialed I'll have to set the idle and fuel mixture screw.
Manual states that the idle be set to 1400rpm and the Mixture screw set to 2 1/4 turns out. Anyone have any tips on dialing in the idle and mixture screws?
Also, to confirm the Mikuni VM's mixture screw is an "air screw", clockwise will make mixture more rich, counter clockwise will lean the mixture?
Thanks guys!
